Harness on top of transmission - Removal
I'm not sure what you attempting to do or the year of you car, please put it in you signature. To me it looks like a 97 and I assuming your trying to remove the transmission. It looks like you still have the throttle body on. I found it makes it a lot easier to get the transmission out with it removed on the xk8s. What I did was to remove the 2 10mm bolts that hold the bracket and leave the harness connected.
There are two bolts holding the harness in place. I think it took me over 2 hours to get those out. Just working from memory, I think the left bolt is better removed from below going over the transmission and the right bolt can be reached from above. You have to use a 1/4" drive because space is next to nothing
