Popping from the rear? 02 xkr
Old 10-22-2016, 09:14 PM
lossking_'s Avatar
Default Popping from the rear? 02 xkr
Has anyone ever experienced their XKR having some sort of popping from the rear? It usually happens when I put it in reverse, or I accelerate and get off of the gas. I'm not sure what it is or what it could be, and I don't know if I should really be concerned.
Old 10-23-2016, 06:13 AM
jamdmyers's Avatar
Popping is kinda generic and hard to understand, when you put it in reverse is it after you release the brake? Sounds like some drivetrain lash. There are u-joints in the half shaft to both wheels, does it come from one side? These need greased once a year... Also might have a pinion bearing loosening up, do you have any leaks?
lossking_ (10-23-2016)
Old 10-23-2016, 06:17 AM
Jandreu's Avatar
+1 above, there are 6 U-joints in the drive line, plus the pinion bearing that could cause a sound if any of them are going out or have wear.
Old 10-23-2016, 08:53 AM
lossking_'s Avatar
Yes it happens after I release the brake. It sounds one sided from the left. Is this an easy fix you can do yourself? What type of grease do I need? There's no leaks at all.
Old 10-23-2016, 10:14 AM
Jandreu's Avatar
The half shaft U-joints have a standard trees seek on them. Use standard axle grease. They can be accessed by jacking the rear up.
