Try re-starting the bluetooth on the iPhone. Turn the bluetooth off, wait a bit then turn it back on.
thanks!
after one night sleep it worked! |
Originally Posted by veffremov
(Post 1781421)
I'm taking a haiatus from this task. I may start making some more next year.
any chance you would be willing to make this an open source project and share your schematics, parts list, and applicable coding? |
(Post 1781421)
When you do, if you do, I want one! Can I register somewhere? Thanks, Mark B. |
I want one too :) waiting for it :) :icon_musclecar:
Here is the schematics of the D2B board. https://goo.gl/zBroxo
The other component is a Raspberry Pi. In the older versions I used A+ models, in the newer ones I use Pi Zero. Here are instructions how to re-build the software for the Pi, for the enthusiasts: https://goo.gl/sK8ZBV |
updates?
Veffremov any update on these? I really want one for my car and don’t want to break the bank with a whole new system since I got alpine and nav, I’ve got an s type R.
I would like to order one. Is it still available anywhere? I couldn't find it.
Hi @Vreffmov I am also interested in this!
Wow - this looks amazing
(Post 1269773)
@trosty the kit should have 2 USB cables one long (6ft) and one short(1ft), connect the short cable to the device then the long cable to the short one, finally the end of the long cable is connected to the USB dongle and that is mounted on the rear shelf close to the speakers.
Route the USB cables so you will have easy access where the short cable connects with the long cable. To perform SW update disconnect the long cable from the short cable and plug a USB stick. I personally let the two USB cable junction hang from the stack and behind the door for easy access. See pic. |
Originally Posted by DSV8
(Post 2415814)
Are these kits still available to buy? I've been looking for a solution to get streaming to my X358 for the last three years and haven't come across anything that seems quite so elegant a solution
Awesome - thanks for this info. I think you've just given me a project for my next holiday..... and emptied my wallet somewhat. However, as you say, it looks like the JagDroid systrem will completely modernise the experience.
I have the veffremov's module, but forgot how to reset the paired devices list, which if I remember correctly has only 5 slots and now can't pair another device. It was supposed to be done through a sequence of selecting "disks" on the cd changer interface. If anyone has the details, I will highly appreciate it!
After some digging in the source code, I found it myself :) The sequence is 534.
Do you have any of these for sale? God I hope you do. Thanks, Brian
Does anyone have one of these for sale by any chance? Thanks.
Originally Posted by mrvip
(Post 2418639)
Love this streamer. Its great. Thanks. |
