F-Pace Keyless Entry Option
Hello
Recently purchased an Australian 2019 MY19 25d R Sport F-Pace. Doesn't have keyless entry?
One spec I read said its standard, One spec says option.
Can this option be added now?
Back in 1990s keyless entry were integrated with alarm systems. Ask a technician that install alarm systems in your area. It's very easy, I installed an alarm system with integrated keyless system and it worked perfectly fine in my 1985 318i BMW that has automatic door locks without keyless entry. That was way back in the 1990s.
”Keyless” used to mean your car has the remote fob which locks and unlocks your car. I’m sure you have that because the car’s push to start would not work without it.
Now it means you approach the car with the fob in your purse or pocket and touch the back of the door handle and the car unlocks.
This is an option. If your door handles have little push buttons on the outer side of the handle, which locks the car, then you have keyless entry.
If you do not have the little buttons then you don’t have keyless entry and I’m sure it would be prohibitively expensive to retrofit.
In the US at least, there is no aftermarket solution for remote start and theft protection for JLR products.
In Canada I’ve heard there is a theft tracker available. Not sure about Down Under.
hemlock
F-Pace (X761) / C-X17
Mar 15, 2016 10:12 PM
