F-Pace (X761) / C-X17 2016 - Onwards
No infotainment sound when outdoor temperature is low.
Old Mar 26, 2025 | 04:04 PM
Jackson Cage's Avatar
Question No infotainment sound when outdoor temperature is low.
My infotainment system worked well unitl this winter when the outdoor temperature was below 10C . Below this temperature I get no sound from the unit when the vehicle is first started. If the vehicla is driven for an hour or more and the cabin is warmed up the sound will return. The amount of time varies depending on how cold it was before the vehicle was started. As outdoor temperatures have begun to rise now this spring I get sound when temperatures stay above 10C. If the overnight temperature is less than 10C then it takes a bit until the cabin warms up to get sound. Has anyone seen this problem?
Old Mar 27, 2025 | 12:44 PM
Just Me's Avatar
Sounds like your battery may be getting weak. There's a module that will turn off the infotainment system when the battery charge drops below a certain point and allow it to turn back on when it's charged again. Cold temperatures affect battery output. You should have your battery tested to see what the life expectancy is. State of Health (SOH): The battery's overall condition and its ability to deliver power under load, including factors like internal resistance and capacity
Old Mar 27, 2025 | 01:01 PM
Thank you for the input. The battery was replaced in June of '24, to rectify the Auto Start not functrioning. There were no infotainment issues before then and the Auto Start still works. I've checked the battery on a couple of occassions and it is consistently at 12.35V before starting, even at minus 30C here in Alberta. Maybe the module is malfunctioning though. I will have to see about having that checked.
Old Mar 28, 2025 | 12:43 AM
Just Me's Avatar
12.35V before starting is a dead battery. 12.6 to 12.7 is fully charged.
Old Mar 28, 2025 | 02:34 AM
Thanks. I learned something new. I will have the battery and alternator checked.
cornponious
Feb 9, 2025 03:11 PM
jomo
Apr 5, 2022 01:04 PM
Dell Gailey
Aug 23, 2018 03:07 PM
Misujerr
Jun 25, 2017 02:10 PM
miamijag
Aug 4, 2014 01:22 PM
