Problems with 2018 F-Pace S
Good afternoon all; curious if any of you are experiencing or have experienced:
1. Oil leaks from the 'variable timing' covers (I believe this is what the Service Dept told me) 2. Squeaky brakes (changing brake pads due to known problem - guessing they are softer material and prob won't last as long and generate more brake dust) The vehicle has roughly 2000 miles on it. Thanks in advance! |
Dealer just called with update - oil leak turned out to be 'oil filter housing' and not 'Variable Timing' cover as suspected.
Still disappointed with early hour quality of vehicle to date....guess nearly $80K doesn't buy you what it used to...lol |
All car fail from time to time. You just got unlucky.
I had the squeaky brake issue as well. New pads corrected it...
