14 V6 Ftype side skirts
i have a 14 ftype v6 380 hp convertible, i like the side skirts on the v8s, looked in all accessory catalogs with jag, where can i buy them and how much? help!
Welcome to the forum dmb1621,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to F-Type forum. Members here with the same model will be able to help. Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
what side skirts? are you talking about the design pack?
Yes, he is, but only the trim pieces that fit on the bottom of the rocker panels. I like them too. The rest of the "design package" is not of much interest.
I wanted these as well and investigated them when I got mine last year. The parts cost $1800 plus paint and install. A little pricey for me but if you find them cheaper please share as I love the look also.
My dealer said they are not sold separately? If someone finds them...please share information as I'd like to add them as well.
if you do a search my old post about a year ago has the part numbers listed I just dont know how yto find the post but it is all broken down in there.
https://www.jaguarforums.com/forum/f...nsions-107953/
If you click on your screen name, there's an option to see all of your previous posts. |
Item numbers refer to the above diagram in post #2.
5.0 Litre Supercharged Item 1 - Body Side Moulding LH Sill : T2R10396 RH Sill : T2R10395 Item 3 - Mounting bracket (Front) LH : T2R3969 RH : T2R3968 Item 4 - Mounting bracket (Rear) LH : T2R3971 RH : T2R3970 Item 8 - Finisher Panel LH Sill : T2R3565 RH Sill : T2R3564 there you go hope it helps let me know if you find these at a good rate |
let me know guys thanks
Has anyone tried to just buy and add the "Finisher Panel" on each side? They are $383 each, and I'm assuming it's just a couple bolts and washer to fasten them. I'm seriously considering ordering them and seeing if they will just bolt on my V6 convertible
Originally Posted by JMichael_LA
(Post 1185580)
All told, cost me around 800. |
the parts department at San Jose British motors told me that if I wanted the finisher panel in the same color as my car, I would have to get it painted. they quoted me $225 each if I remember correctly.
supposedly it's current coating is primer. |
