Originally Posted by FIRE550
(Post 2281081)
Its not a red triangle it is a circle the size of a dot. Blinks red only when the car is locked and off. Soon as I unlock the doors leaving them unlocked and car off the light stops.
I would think this has to be the security system. |
Originally Posted by scm
(Post 2281144)
sov211 was referring to the hazard switch light, not the security lamp. So your thought is correct. ;)
(Post 2280644)
Battery disconnect involves removing the negative lead from the battery for half a minute or so. That resets any modules that have been locked on by the use of the OBD port. It's a known quirk, not everything you plug into the OBD has the effect but many do. I believe the symptom is that the light stays on in the hazard switch if the problem has occurred - check it an hour after locking the car and if it's on, do the battery disconnect!
Now your battery has gone flat I suspect the modules will have reset already. Battery should be fine after a recharge. |
(Post 2280644)
