Cruise control missing
Hi guys,
My F-type I bought doesn't have cruise control. Is it possible to install it aftermarket? Thanks, Christophe |
This is unusual. I heard about bare-bones F-types, but only for sale in UK.
In BMWs they don't offer rear fog lights in U.S. spec models, but you can add it just by replacing the headlight switch with a European model switch. Perhaps adding the switch would also add the feature since it isn't that complex. Many times its cheaper to just take away the switch than make 2 different wiring harnesses/software packages that increase plant complexity.
Well, the option was not selected when the car was bought new.
So where the buttons normally are on the steering wheel there is a plastic cover. |
Originally Posted by Christophe
(Post 1783427)
You will probably need a new steering wheel with CC (plenty available on Fleabay or from Rimmer Bros) and then you would need someone to tweak the CCF using SDD to turn the system on.
Originally Posted by OzXFR
(Post 1783497)
(Post 1783269)
Hi guys,
My F-type I bought doesn't have cruise control. Is it possible to install it aftermarket? Thanks, Christophe Did you got to solve this issue? Thanks |
Help!!!
Without Cruise control this car became a bit annoying on longer trips, my knee and foot got numb all the time... I really need to find a solution for this perhaps someone can indicate a expert that might can solve this. Arden told me they can only sell me the steering wheel but no coding the CC buttons.... |
[QUOTE-bcbruno;2248952] ˇˇˇAyuda!!!
Sin control de crucero este coche se convirtió en un poco molesto en viajes más largos, mi rodilla y el pie se adormeció todo el tiempo... Realmente necesito encontrar una solución para esto tal vez alguien pueda indicar un experto que pueda resolver esto. Arden me dijo que sólo pueden venderme el volante, pero no codificar los botones CC.... [/QUOTE] Hola, Alguna noticia nueva sobre su duda, tengo el mismo problema. Gracias |
Originally Posted by Stohlen
(Post 1783346)
Originally Posted by eeeeek
(Post 2268296)
Side note: I hate rear facing fog lights. Why? Because every jackass with a Merc or Audit that has them drives around with them on ALL THE TIME.
