Thank you. I suppose I must have taken out that center floor panel at some point but I honestly do not remember. I would not under any circumstances have recognized the second battery inside of it’s partial housing. I had thought it might be in the engine compartment.
I am surprised no one has tried a Lithium Ion Battery in the F Type.
Originally Posted by mlebofsky
(Post 1845851)
Originally Posted by Unhingd
(Post 1845907)
I will probably go that way when I actually need to replace the original battery, but I initially balked at the $1300 price tag. |
Dieting a F-Type is like a Super-model going on a diet... COMPLETELY unnecessary.
Having said that the VERY FIRST thing that ANYONE should do is to change the disc to ceramic and the wheels to the SVR alloys. If someone does not want to do either of those because it's too expensive then please see my 1st sentence as "care and feeding" of super-models is expensive. |
Originally Posted by ndabunka
(Post 1845925)
Having said that the VERY FIRST thing that ANYONE should do is to change the disc to ceramic ... |
I'm less interested in carbon/ceramic brakes as some nicer calipers. I haven't hefted one of those fronts but they look like anvils. Opposed piston Brembos would be my choice. It's not like JLR didn't have them in the parts bin. Even Subaru puts them on their sportier models. Seriously, why not Jaguar?
Originally Posted by lizzardo
(Post 1846238)
OK turns out Brembo do a full kit:
https://www.racetechnologies.com/pro...?vehicle=11098 Very nice, quite tempted by those, a shame they don't offer a rear kit also. :( |
Originally Posted by Gibbo205
(Post 1846245)
I am surprised Brembo, Alcon or AP do not offer a big brake kit for the F Type for front and year as not all of us have ceramics and the steels use pretty ugly calipers and the disc are very heavy solid 1pc items.
There is also this kit for the XF:
https://www.racetechnologies.com/pro...ts/gt-1n-9056a That uses 380mm x 34mm disc which I believe are same size as F Type front disc so I wonder if the disc from that kit would be a direct bolt-on to our cars. |
(Post 1846253)
https://www.racetechnologies.com/pro...ts/gt-1n-9056a That uses 380mm x 34mm disc which I believe are same size as F Type front disc so I wonder if the disc from that kit would be a direct bolt-on to our cars. For an SVR (like you have) then the first kit you linked to would be better as long as you already have the wheels that will fit around the 405 mm discs & calipers ("Storm"???), but those 405s will be too big for any other F-Type unless it already has the CCM brakes and therefore the bigger wheels. |
Originally Posted by F-typical
(Post 1521794)
Mine came with the lightweight aluminium roof - for free...
Originally Posted by 4x4uk
(Post 1846651)
yep mine did to, so glad because I did not want a glass roof
You are right as Jaguar in the past did use Brembo's from the factory.
My 2005 S Type R had them but Jaguar dropped them on that car for 2006 and up. Still have never found a reason why and the non-Brembo brakes certainly seem to stop the car good enough? We have heard that the cost of the Brembo's was a big factor but again you see them on much cheaper cars so I am not sure that's correct? I have an XJR and it's rated as one of the 20 quickest stopping cars ever recorded? Fast Brake: 20 Best 60 to 0 Distances Recorded by Motor Trend When a car the size of an XJR can stop from 60 mph in 99 feet that saying something! . . . |
The cheapest way to save weight is probably to order a car without the glass roof, wingbacks, stereo upgrade, supersized brakes* or anything larger than 18”wheels.
So basically a V6 Base. HTH. 🙂 * I bought some. They are really HEAVY... |
(Post 1846248)
(Post 1846938)
(Post 1846938)
So basically a V6 Base. HTH. 🙂 * I bought some. They are really HEAVY... Dave |
I've the R...the one that was 4020# on the celebrated " what do they weigh" thread.
Checked on the scales this morning ( bathroom scales) and my goal is a much needed 35# reduction....won't cost anything like $4000+/- for fancy brakes....in fact I figure I'll net $4000 or so as I'll be also reducing my daily wine and cheese ration. YMMV Alan |
