F type rear subframe change
Old Nov 7, 2017 | 10:37 AM
Anil4565's Avatar
Default F type rear subframe change
Hi guys have had the rear subframe replaced in my f type does anyone know what can be adjusted in the rear and front suspension ie camber, toe, castor
cheers
Old Nov 7, 2017 | 10:52 AM
NBCat's Avatar
Did the shop that replaced the rear subframe perform an alignment, which should be part of the operation?
Old Nov 7, 2017 | 01:43 PM
ShaunPA's Avatar
front has a small camber adjustment. rear has none. toe/caster can be adjusted front and rear.
