Flat bottom steering wheel
Hi it's Tommy.
I'm currently thinkg abat swaping my steering into black flat bottom steering wheel. I wonder if i'm right, flat bottom on is more thicker. Searched throughout the threads but can't find exact answer. am I right? |
Originally Posted by TAEUCK Goo
(Post 2165176)
Hi it's Tommy.
I'm currently thinkg abat swaping my steering into black flat bottom steering wheel. I wonder if i'm right, flat bottom on is more thicker. Searched throughout the threads but can't find exact answer. am I right? This is the one I have been looking to buy for many years now, just waiting/hoping for it to be reduced to 40/50% off: https://rimmerbros.com/Item--i-T2R4641PVJ |
Many thanks for the fast reply Oz!.
I saw the items on your link but it has no heating while mine has it. Anyway, a bit thicker huh? I should go on! Thank bro. |
(Post 2165242)
I swapped the standard wheel in my car to the flat bottom sport steering wheel, best thing I ever did. The sport wheel feels so much better in hand (it's definitely thicker all around) and it really enhances the driving experience. The standard wheel does not belong on this car, it's just too plain and skinny.
The other nice thing about the flat wheel is that it gives you a bit more leg room when you get in and out.
Hello Taeuck,
I have a Type 400 with the "flat bottom" steering wheel. It is certainly thicker than the standard steering wheel. Hope this helps, Frank. |
Definitly hepls old man like me to get in and out, but really just like the way it looks.
Originally Posted by bjg625
(Post 2190353)
... really just like the way it looks.
Do these wheels come with the paddles and the audio and control buttons?
Originally Posted by 2004XJ8
(Post 2190393)
Any coding required, or a straight swap? (forgetting about potentially retrofitting heated steering)
Originally Posted by sov211
(Post 2190530)
If your question means: When installed does the flat-bottom wheel have the paddles and the audio/cruise controls installed? the answer is YES. If the question means: does a new, uninstalled wheel include those controls? The answer is NO. You transfer the controls to the new wheel, unless you buy a used one which includes the controls.
Thank you Frank .
really help . Thank you! I need to go to Ebay for purchase. |
If it has a flat bottom, should it not be called something other than a wheel?
"Wheel definition is - a circular frame of hard material that may be solid, partly solid, or spoked and that is capable of turning on an axle." I propose that the steering implement with a flat spot in an otherwise circular object that is used to directionally control an automobile be called a Pointer. |
Originally Posted by Ftypelover
(Post 2191238)
"Wheel definition is - a circular frame of hard material that may be solid, partly solid, or spoked and that is capable of turning on an axle." I propose that the steering implement with a flat spot in an otherwise circular object that is used to directionally control an automobile be called a Pointer. I'd still like to know if a new wheels is plug and play... assuming like for like. |
(Post 2191238)
Originally Posted by scz4
(Post 2191241)
I think it's called so because it's a contraption steering the wheels (those round things upfront with tyres) :D :D
Sorry to raise this again, but I think I've found a flat bottomed wheel which comes with no trim, buttons etc, but it is heated
My current wheel isn't heated and I don't plan to retrofit this as it sounds like a real hassle. But if I transfer my paddles\buttons\trim etc will it still be plug and play?? Or is it physically a different fit on the steering column? Part number is T2R20989PVJ |
(Post 2199914)
