Flat bottom steering wheel
Old Dec 10, 2019 | 07:02 PM
TAEUCK Goo's Avatar
Default Flat bottom steering wheel
Hi it's Tommy.
I'm currently thinkg abat swaping my steering into black flat bottom steering wheel.
I wonder if i'm right, flat bottom on is more thicker.
Searched throughout the threads but can't find exact answer.
am I right?
Old Dec 10, 2019 | 07:35 PM
OzXFR's Avatar
Originally Posted by TAEUCK Goo
Hi it's Tommy.
am I right?
Hard to tell without having both in front of me, but the flat bottomed wheel (correct name "sports" wheel) looks to me to be maybe a tiny bit thicker in most places and obviously much thicker where the "grips" are at the 10 o'clock and 2 o'clock positions.
This is the one I have been looking to buy for many years now, just waiting/hoping for it to be reduced to 40/50% off:
https://rimmerbros.com/Item--i-T2R4641PVJ
Old Dec 11, 2019 | 01:49 AM
TAEUCK Goo's Avatar
Many thanks for the fast reply Oz!.
I saw the items on your link but it has no heating while mine has it.
Anyway, a bit thicker huh?
I should go on!
Thank bro.
Old Dec 11, 2019 | 02:03 AM
OzXFR's Avatar
I should go on!
Thank bro.
The one I linked to is heated, it's just that the stock pic they use for the ad shows a non heated one (no button top left of the right side steering wheel controls).
Old Dec 11, 2019 | 07:38 PM
Jaaaggg's Avatar
I swapped the standard wheel in my car to the flat bottom sport steering wheel, best thing I ever did. The sport wheel feels so much better in hand (it's definitely thicker all around) and it really enhances the driving experience. The standard wheel does not belong on this car, it's just too plain and skinny.
Old Dec 12, 2019 | 01:03 AM
Uk2usa's Avatar
The other nice thing about the flat wheel is that it gives you a bit more leg room when you get in and out.
Old Feb 11, 2020 | 03:50 PM
Frank Gama's Avatar
Hello Taeuck,
I have a Type 400 with the "flat bottom" steering wheel.
It is certainly thicker than the standard steering wheel.
Hope this helps,
Frank.
Old Feb 12, 2020 | 12:40 AM
bjg625's Avatar
Definitly hepls old man like me to get in and out, but really just like the way it looks.
Old Feb 12, 2020 | 03:26 AM
scm's Avatar
scm
Originally Posted by bjg625
... really just like the way it looks.
... and feels. The round wheel felt quite skinny to me.
Old Feb 12, 2020 | 03:56 AM
2004XJ8's Avatar
Do these wheels come with the paddles and the audio and control buttons?
Old Feb 12, 2020 | 11:12 AM
sov211's Avatar
If your question means: When installed does the flat-bottom wheel have the paddles and the audio/cruise controls installed? the answer is YES. If the question means: does a new, uninstalled wheel include those controls? The answer is NO. You transfer the controls to the new wheel, unless you buy a used one which includes the controls.
Old Feb 12, 2020 | 12:00 PM
scz4's Avatar
Any coding required, or a straight swap? (forgetting about potentially retrofitting heated steering)
Old Feb 13, 2020 | 03:28 AM
2004XJ8's Avatar
Thank you for the answer. I was wondering if I had to transfer existing controls to the new wheel.
Old Feb 13, 2020 | 05:54 PM
TAEUCK Goo's Avatar
Thank you Frank .
really help .
Thank you! I need to go to Ebay for purchase.
Old Feb 14, 2020 | 09:00 AM
Ftypelover's Avatar
Banned
If it has a flat bottom, should it not be called something other than a wheel?
"Wheel definition is - a circular frame of hard material that may be solid, partly solid, or spoked and that is capable of turning on an axle."
I propose that the steering implement with a flat spot in an otherwise circular object that is used to directionally control an automobile be called a Pointer.
Old Feb 14, 2020 | 09:04 AM
scz4's Avatar
I think it's called so because it's a contraption steering the wheels (those round things upfront with tyres)
I'd still like to know if a new wheels is plug and play... assuming like for like.
Old Feb 14, 2020 | 09:53 AM
scm's Avatar
scm
But I was taught that it's rude to point! And the F-Type slogan was "it's good to be bad", not "it's good to be rude".
Old Feb 14, 2020 | 04:02 PM
OzXFR's Avatar
Yep, if it is like for like it will plug and play.
Old Mar 5, 2020 | 09:22 AM
scz4's Avatar
Sorry to raise this again, but I think I've found a flat bottomed wheel which comes with no trim, buttons etc, but it is heated
My current wheel isn't heated and I don't plan to retrofit this as it sounds like a real hassle. But if I transfer my paddles\buttons\trim etc will it still be plug and play?? Or is it physically a different fit on the steering column?
Part number is T2R20989PVJ
Old Mar 5, 2020 | 03:27 PM
Unhingd's Avatar
It should be a plug and play.
