Flat bottom steering wheel
Received 3,148 Likes
This is the one I have been looking to buy for many years now, just waiting/hoping for it to be reduced to 40/50% off:
https://rimmerbros.com/Item--i-T2R4641PVJ
The one I linked to is heated, it's just that the stock pic they use for the ad shows a non heated one (no button top left of the right side steering wheel controls).
I swapped the standard wheel in my car to the flat bottom sport steering wheel, best thing I ever did. The sport wheel feels so much better in hand (it's definitely thicker all around) and it really enhances the driving experience. The standard wheel does not belong on this car, it's just too plain and skinny.
scm (12-12-2019)
If your question means: When installed does the flat-bottom wheel have the paddles and the audio/cruise controls installed? the answer is YES. If the question means: does a new, uninstalled wheel include those controls? The answer is NO. You transfer the controls to the new wheel, unless you buy a used one which includes the controls.
If it has a flat bottom, should it not be called something other than a wheel?
"Wheel definition is - a circular frame of hard material that may be solid, partly solid, or spoked and that is capable of turning on an axle."
I propose that the steering implement with a flat spot in an otherwise circular object that is used to directionally control an automobile be called a Pointer.
I'd still like to know if a new wheels is plug and play... assuming like for like.
But I was taught that it's rude to point! And the F-Type slogan was "it's good to be bad", not "it's good to be rude".
Sorry to raise this again, but I think I've found a flat bottomed wheel which comes with no trim, buttons etc, but it is heated
My current wheel isn't heated and I don't plan to retrofit this as it sounds like a real hassle. But if I transfer my paddles\buttons\trim etc will it still be plug and play?? Or is it physically a different fit on the steering column?
Part number is T2R20989PVJ
