Group Buy: (4) Motorsport Tech hubcentric adapters/spacers
#103
Chester///M (01-12-2018)
#104
Nice pictures Burt. Ok are these 15mm or 17mm spacers on your wheels? all around?
I suspect 17mm all around. And you have absolutely no rubbing or scraping? ever?
Thanks for your time and the pictures.
and the tires are 295 rear and 255 front, standard OEM tire sizes? did you have to grind/ shave studs?
#106
one comment that I want to add to Burts detailed write-up on grinding the studs is that you "should' screw the lug nut onto the stud BEFORE you cut/grind/etc.... just in case you touch the threads, backing the lug nut can help with any re-threading or thread correction when backing it off.
One thing I also want to ask is that you said you are 'not cutting', .you are grinding'. Are you really not just trying to lop off the non threaded end of the stud? Are you actually trying to grind vs cut?
#108
lets try to close this list out by the end of the weekend or early next week. We have 7 total, of which 6 have a 15mm preference and 1 17mm preference.
For anyone on the list, please put whether you want them black anodized or not.
For anyone that is a new owner, it may pay to take advantage of the group buy now if you ever have aspirations to get spacers.
1. watson6505 (15, 17) Black
2. itismejoshy (15, 17)
3. vettegood (17 ONLY) Black
4. Donzi38ZXXX (15, 17)
5. Chester///M (15 ONLY)
6. Tork Monster (15, 17)
7. lizzardo (15,17)
8.
9.
10.
11.
7. lizzardo (15,17)
8.
9.
10.
11.
The following 4 users liked this post by Unhingd:
Burt Gummer (01-12-2018),
Chester///M (01-12-2018),
indietor (01-12-2018),
Tork Monster (01-12-2018)
#113
Received 3,126 Likes
#114
Hardened steel. You'd wear out several hacksaw blades on every stud (if it's even possible). A small angle grinder should cost you less than AU$100.
OzXFR (01-12-2018)
#116
#117
#119
#120
Link to cheap grinders @ HF for those who need one (there is one for $11...prolly good for one use, lol):
https://www.harborfreight.com/catalo...rs+and+buffers
