Hood alignment shifted at high speeds
Hoping someone has gone through this. I am on a road rally with my SVR.
on the first leg I got up to around 190mph. I started noticing that the hood seems to be catching wind and moving around so I slowed down and checked when we stopped. the hood has shifted back into the door panels. And the gap it creates let’s in air which flexes the hood at speed... and suggestions for roadside diy repairs? I’ve taped up the gaps to stop air from flowing in and causing any more shift but the hood is far enough back to rub on the doors when you open them. |
The main things holding the hood in place are the four 16 mm bolts on each of the two front hinge plates, and they do allow some leeway for fore/aft adjustment.
So that is the first thing I would check - loosen off those eight bolts just a tad, push/pull the hood forward a tiny amount, then do them up good and tight. Much easier with a helper than by yourself, don't ask how I know this! |
Where do you get to drive 190mph??
Profile indicates OP is from South Africa.
Originally Posted by cpq100
(Post 2364649)
We have loads of deserted roads out in the Country. |
Originally Posted by Biofreak
(Post 2364652)
Exactly there ;)
I just checked and saw South Africa uses the metric system. Might that 190 mph be 190 kmh?
Originally Posted by scm
(Post 2364654)
And no speed limits? Or highway patrols?
as an update, my rally got even worse. I blew a CV or rear diff. Oil all over the rear with a rattling loose coupler. |
(Post 2364655)
