Low wiper fluid warning and leak
Hey guys have a 2014 f type s convertible and it recently said low wiper fluid warning. Added some and light went away. Next day saw large pool under pass side front tire. Pulled tire off and wheel cover back and saw front reservoir full and it appeared to be coming from behind the plastic container towards the rear. Drove few more times and light does come and go. Any thoughts is it the sensor bad? I noticed 2 there (made in China go figure) or could it be a floater bad inside?
thanks |
Originally Posted by Jasper’ftype
(Post 2305080)
thanks Likely going to have to pop it out and inspect it to see which one it is. Probably leaking and the back tank is re-filling...then the back tank gets low and the light goes on. Good luck, DC |
Should look like this https://parts.jaguarlandroverclassic.../brand/jaguar/
Make sure the 2 pumps are not leaking. https://www.google.com/url?sa=i&url=...AAAAAdAAAAABAD |
Thanks fellas I will remove tank and examine see if I can pinpoint the leak and thanks
(Post 2305914)
DC https://cimg7.ibsrv.net/gimg/www.jag...71b079aa80.jpg |
