Mystery Button on Steering Wheel...voice command?
I just took delivery of a 19MY and have what seems to be a "Voice Command" button on the left of my steering wheel, between the Phone button and the Mode button. I can press and depress it nicely, but it does not respond to any voice command (I do not have a list of what commands it might understand, so I am not sure). This button does not appear on any picture of F Type on the JLR web sites, or in any section of the manual. It seems to turn the media on and off, but I can't imagine that is its real purpose. Here is what it looks like: Do we now have "voice commands" on the F Type? Is this part of the new Touch Pro in preparation for CarPlay etc.? Any insights appreciated, thank you.https://ecp.yusercontent.com/mail?ur...na.nMEnnkg--~C |
My understanding is that voice commands may be enabled in a ICTP update, but I would have thought your new F-type would have that. I need to update the ICTP software on my MY18 XE at some point.
Anything about it in the manual?
Originally Posted by scm
(Post 1973180)
Should work..
InControl Touch navigation makes planning journeys and following routes easy thanks to turn-by-turn voice guidance, junction view and 3D maps. Set your destination with a few taps, or simply speak a command. The system will then allow you to choose the fastest or most economical route7. Once you are on your way, live traffic capability offers redirection if a quicker route arises. https://www.jaguarusa.com/owners/inc...rol-touch.html |
I gave up on that system. Waze is far more accurate and effective. |
Originally Posted by Unhingd
(Post 1973236)
Originally Posted by fujicoupe
(Post 1973257)
Can you use that through the car's touch screen? I see that Sygic, Genius Maps and In-Dash (a Tom-Tom product) are available as Apps but Waze isn't.
Haven’t played with mine, but was under the impressin that button was related to the bluetooth function for using your phone? |
(Post 1973236)
Originally Posted by Brock
(Post 1973271)
JLR just announced that they would soon support CarPlay, which allows you to have Waze on your touch screen (see https://www.macrumors.com/2018/09/26...united-states/). This will require you to have Incontrol Touch Pro though.
there is no voice command on latest infotainment afaik
the new 10" screen is more like a lite version compared to it in other vehicles, i would assume because they couldn't fully integrate all the features/tech into the existing f-type canbus designed 5 odd years ago all the new f-types i've seen, including the older cars, just had a blank switch there i think someone at factory has just installed the wrong button panel lol |
It is a mute button, from memory. Hold fire I dont know if it is, I'll check tonight.
(Post 1973374)
The steering wheel had the exact same button for turning JagVoice on and off but it did not work as a mute button. However on my old XFS which did not have JagVoice the same button worked as the mute button. Strangely I miss that mute button on the F-Type! |
Originally Posted by PolkNole
(Post 1973370)
While this is (finally) great news, why is it that JLR is so late to the party? Technology is not Jaguar's strong suit.
On earlier F-Types that button was blanked, but it is worth pointing out that you can add that button to any F-Type since the 2014 launch model and you will gain a mute button. (The hardware is already in the switch pack - only the key cap needs to be swapped over.) On other models it is either a mute button or a voice activation button depending on whether that feature is enabled, so if Jaguar have started offering it from the factory with that button then it sounds like an update is coming either to their infotainment system or via an app as others have mentioned.
Interestingly all the hardware for the voice control was there since launch but not activated. With the IAM cars (pre 2016) the appropriate "Voice Control" CCF byte can be set to "Advanced speech recognition" but I didn't have the missing button the last time I played with my car. I have since added it when I replaced the buttons for the sticky paint problem so I will have another play next time to see if it can be enabled. I don't know if the next gen infotainment would follow the same route as I don't have access to that. As it is a hardware-less feature to add to the F-Type I suspect it was not offered at launch due to the cabin noise. |
Yes it is a blank in my car but a voice activation button in my wife's, so it seems. We have never used it, but it was happy enough to be activated when I just tried.
(Post 1973171)
I just took delivery of a 19MY and have what seems to be a "Voice Command" button on the left of my steering wheel, between the Phone button and the Mode button. I can press and depress it nicely, but it does not respond to any voice command (I do not have a list of what commands it might understand, so I am not sure). This button does not appear on any picture of F Type on the JLR web sites, or in any section of the manual. It seems to turn the media on and off, but I can't imagine that is its real purpose. Here is what it looks like: Do we now have "voice commands" on the F Type? Is this part of the new Touch Pro in preparation for CarPlay etc.? Any insights appreciated, thank you. |
(Post 1973257)
On my MY19 it acts as a mute button (for when you get pulled over). |
