Unhingd
close
- Join DateDec 2014
- LocationMaryland, US
Liked:4,727 Times in 3,407 Posts
Quote:
+1.Originally Posted by OzXFR
..., but meh I took it off months ago and it's staying off!
I like the idea of dissipating heat quicker by removing the cover. I also like the idea that zmoothg had with the cover; cutting out sections and adding the mesh. Seems a reasonable compromise between cooler and ugly. I also want to keep the cover as is, so I need another one (V6).
I did a google quick search and found a few around from $90 US to $250, just wondering if anyone has purchased one, or has any suggestions on a good source that is not Jaguar dealer?
CRS 123
close
- Join DateMay 2016
- LocationLos Angeles
Liked:83 Times in 59 Posts
Just curious, So w/o cover, some temp reduction and some faster cooling... so are there significant enough temp differences where engine performance etc can be measured?
CRS
CRS
Quote:
CRS
Fair question. Originally Posted by CRS 123
Just curious, So w/o cover, some temp reduction and some faster cooling... so are there significant enough temp differences where engine performance etc can be measured? CRS
For me I am not directly trying to get performance, more concerned that with the VAP crank pulley upgrade and assumed increase in heat with the SC, better cooler is a good thing. It may all be in just in my head and it will not make a difference.
Does anyone here who has removed their engine cover also have the entire hood wrapped in PPF? I know that paint was a slight concern with the heat but I feel like the adhesive from the PPF would be quite vulnerable to the high amount of heat radiating from the top of the engine.
Quote:
It may be for protection as the engine does move and the inter-cooler on the SVR is upgraded from the R.
Hello. Were you able to find a part number on the shield that is mounted under your hood?Originally Posted by MaximA
I looked for a part number last night and couldnt find one, but a 3/4 in thick piece of dense yet pliable material. I checked Topix as well and couldnt find it the part but I didn't put in my VIN. Let me look again with the VIN entered and see if I can find some more information.It may be for protection as the engine does move and the inter-cooler on the SVR is upgraded from the R.
Unhingd
close
- Join DateDec 2014
Quote:
I have had the cover off for at least 12,000 miles and it has had no impact on the xPel.Originally Posted by BigDuke
Unhingd
close
- Join DateDec 2014
Quote:
I believe this is the part number for the SVR insulation pad: Originally Posted by BigDuke
T4N2639
Not worth it for $420.
Quote:
T4N2639
I don't think that's it -- it's a different shape (bigger and rounded) compared to what's shown here: https://www.jaguarforums.com/forum/f...6/#post1575984Originally Posted by Unhingd
I believe this is the part number for the SVR insulation pad: T4N2639
Unhingd
close
- Join DateDec 2014
Those parts sketches aren't always true to life.
Unhingd
close
- Join DateDec 2014
http://www.ebay.com/itm/like/2915982...&ul_noapp=true
I'm wondering if I could find a generic heat shield from another car and just cut out a piece and fix it to the hood.
Uncle Fishbits
close
- Join DateJan 2015
- LocationTiburon, CA
Liked:721 Times in 412 Posts
is it possible you won't know until you actually remove the xpel?
Unhingd
close
- Join DateDec 2014
Quote:
I'll let you know in another 8 years.Originally Posted by Uncle Fishbits
Quote:
Here's where I normally start when looking for any kind of heat shielding:Originally Posted by BigDuke
COOL-IT Thermo-Tec ? Heat and sound insulating products
DPelletier
close
- Join DateFeb 2016
- Locationkelowna
Liked:334 Times in 258 Posts
Quote:
Possible? yes, Likely? no......I'd bet good money that the paint can take more heat than the wrap can.Originally Posted by Uncle Fishbits
2 cents,
Dave
This seems ideal to me. I just wonder if the adhesive backing will cause any damage to the paint.Originally Posted by lizzardo
Here's where I normally start when looking for any kind of heat shielding:COOL-IT Thermo-Tec ? Heat and sound insulating products
Thermo-Tec Automotive - 24" x 36" ADHESIVE BACK
I can't imagine it would. It's designed to protect painted surfaces. I havenb't used that exact product, but I've used a number of their others over the years and have always been satisfied. That's probably the one I'd use if I do remove or vent my engine cover.Originally Posted by BigDuke
This seems ideal to me. I just wonder if the adhesive backing will cause any damage to the paint.Thermo-Tec Automotive - 24" x 36" ADHESIVE BACK
