Fuel Line for Brake Line?
I need to cut 4 short pieces of rubber hose for the non-pressurized brake lines from the reservoir to the master cylinder. No one in town seems to have brake specific rubber hose, but I was told high quality fuel line will work just as well.
Thoughts? |
I know EXACTLY the pieces you are referring to, and YES, it will suffice.
Eventually the brake fluid will "leech" thru this hose, but it takes about 12 months. I use EFI rated 6mm hose, and have never had fluid contamination issues. On our S2 and XJ-S I eliminated those metal pipes and simple ran that hose from the container to the master cylinder direct, less joints to weep was my thinking. |
You could always buy a brake hose with the ends on it and just cut what you need from it. Of course you need to ensure that the ID is right.
Originally Posted by plums
(Post 640147)
Thanks to you all. I wnet with the blue braided clutch/brake liners often used for porsche/vw applications. Now, I just need to find a suitable gasket for my reservoir cap. So far, no good.
I am getting there. "If it was easy, anyone could do it." |
