Supercharger belt
Hi , my 4.2 xkr have this supercharger belt:
2W93 8620 EB i have a stage 2 upper pulley. Where i Can find It a Little more short belt ? Part Number? Thank you |
I presume your belt is slipping?
I have a similar setup and bought my super charger belt on Ebay and no slipping whatsoever. Its the standard belt for a 2005 XJR. Is your idler pulley setup working properly? |
Originally Posted by jackra_1
(Post 1995822)
Originally Posted by deuce2000
(Post 1996341)
not slipping. Only that will be better a little more short belt
(Post 1996419)
If your existing belt is not slipping then I do not understand why you want a "tighter" belt?
I WANT IT BECAUSE WITH STAGE 2 SMALL UPPER PULLEY IT WILL BE BETTER THAN OEM !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!! understand now? |
Why would it be better? If it is not slipping and is moving the pulley with no problem what benefits would a tighter belt provide?
None I can think of. Hoping to hear...
(Post 1996422)
Ok understand now...
Problem is that on belts that I see advertised they do not give measurements just "compatible vehicles". |
