Request For Help With Signatures
I can't seem to figure out how to get a signature to show up in my posts. I have gone to 'User CP' and created a signature and saved it. I presume that any signature creation/modification will be retroactive and show up in posts made prior to the signature change and not only those posts made following the change. Is this correct? (I suppose if I see my signature at the bottom of this post, it is a sign that such a change is not retroactive.) So (assuming that my sig will not be present in this post) what am I doing wrong?
Update: Looks like I created and saved the signature correctly but that signature changes are not retroactive to older posts. Ugh. |
Glen,
1. Signature changes (either made by the forum member in their User CP or by Moderators in our Control Panel) appear with the NEXT post - not immediately. 2. Changes (or a new Signature) should apply retroactively. I can't see anything wrong with the format or content of your Signature to explain why it has not appeared in your earlier posts. As a test, I've removed the line break between "Regards" and "Glen". Let's see if this edit appears with your next post and what happens to previous posts. Graham |
Ah. Got it. Thanks so much for the reply, Graham! Really appreciate it.
