Clean Black on Black XJR
For Sale
2000 Jaguar XJR
  • 2000 Jaguar XJR - Clean Black on Black XJR - Used - VIN SAJDA15BOYMF16169 - 85,200 Miles - 8 cyl - 2WD - Automatic - Sedan - Black - Sioux City, IA 51106, United States
  • Price
    $11,500
    • OBO
  • Location Sioux City, IA, 51106, USA
  • Condition Used
  • VIN SAJDA15BOYMF16169
  • Trim Base
  • Mileage 85,200
  • Engine 8 cyl
  • Drive Type 2WD
  • Transmission Automatic
  • Vehicle Type Sedan
  • Exterior Color Black
Description:
Beautiful X308 XJR for sale in NW Iowa.
85,000 miles, but presents like one with much lower miles.
Car currently has Coventry Whitley rims that are in pristine condition, but I do have the original Asteroids as well that are also an excellent shape.
I have recently replaced the rear shocks and bushing donuts and a rear wheel bearing along with a small coolant hose to fix a small leak.
Has barely broken in Michelin pilot sports but they are date coded 2018. Not a lot of miles have been put on it the car in the last 8-9 years.
Car turns heads and starts conversations everywhere I go.
The stereo system does need to be gone as I believe in a couple of the speakers foam is possibly deteriorated from age and it doesn't have much for low end bass. It doesn't sound bad, but my 2007 XKR sounds infinitely better.
More importantly, the radio has continual power (even if the car is shut off in the door is open you can still turn the radio back on) and it will drain the battery. For now, I pull the radio fuse underneath the rear seat anytime I'm going to let it sit more than a day or so.
From what I've read on this site it may need a new head unit. Everything else works as it should
Also in the one front photo you'll see a noticeable hood dent above the inner driver side headlight, the dent has been painlessly dent repaired. If you're looking closely you can still see a mark and it does have touch-up paint on it but it's much less noticeable today.
Auto dimmer rearview mirror is darkened/failed and the rear seat middle seat belt trim piece is missing.
I am considering placing on bring a trailer but they are trying to hold me to having a no reserve auction and I'd rather not do that. I figured I would try it here and some of the FB groups I belong to first.
It is a stunner and mechanically it runs out beautifully as it should.
Plenty more photos available upon request
Edit to add I am located about an hour north of the Omaha Nebraska airport and am willing to deliver to the parking garage there for a fly and drive home.  I wouldn't hesitate to drive this car anywhere.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
