Jaguar XJ 5.0L Supercharged Engine Parts - 2011 - Cheap
For Sale
2011 Jaguar XJ
  • 2011 Jaguar XJ - Camshafts and Parts - Engine - Internals - $350 - Linden, NJ 07036, United States
    Expired
    Expired
  • 2011 Jaguar XJ - ENGINE MOTOR PISTONS and Rods - 7 - Engine - Internals - $220 - Linden, NJ 07036, United States
    Expired
    Expired
  • 2011 Jaguar XJ - OEM Fuel Injectors Bosch - Engine - Intake/Fuel - $165 - Linden, NJ 07036, United States
    Expired
    Expired
  • 2011 Jaguar XJ - Engine Computer Brain Box MB279700-9450 P5 - Engine - Electrical - $160 - Linden, NJ 07036, United States
    Expired
  • 2011 Jaguar XJ - Ignition Coil Pack OEM - Set - Engine - Electrical - $140 - Linden, NJ 07036, United States
    Expired
  • 2011 Jaguar XJ - Electrical Wiring Harness OEM - Engine - Electrical - $130 - Linden, NJ 07036, United States
    Expired
  • 2011 Jaguar XJ - CYLINDER HEAD COVERS OEM - Engine - Internals - $120 - Linden, NJ 07036, United States
    Expired
    Expired
    Expired
Description:
I have many engine parts for the car except for the block and cylinder heads.
Car had 36,000 miles on it.
Picture Title Part Category Price Part Description
OEM Fuel Injectors Bosch Engine - Intake/Fuel $165 OEM Fuel Injectors Bosch
Engine Computer Brain Box MB279700-9450 P5 Engine - Electrical $160 Engine Computer Brain Box MB279700-9450 P5
Ignition Coil Pack OEM - Set Engine - Electrical $140 Ignition Coil Pack OEM - Set
Electrical Wiring Harness OEM Engine - Electrical $130  Electrical Wiring Harness OEM
CYLINDER HEAD COVERS OEM Engine - Internals $120 CYLINDER HEAD COVERS OEM
Sold
Camshafts and Parts Engine - Internals $350 Camshafts and Parts
Sold
ENGINE MOTOR PISTONS and Rods - 7 Engine - Internals $220 ENGINE MOTOR PISTONS and Rods - 7
Old Aug 21, 2022 | 10:47 PM
awegrzyn's Avatar
So quick obvious question. When I lower the prices to the point all these parts are the cheapest out there, and I have tons of them on eBay as the cheapest as well, and nobody is buying. Does that mean no one is rebuilding these engines?
I don't even have views on these parts. I will probably lower the prices until it sells, or scrap them.
Old Aug 23, 2022 | 01:45 PM
Addicted2boost's Avatar
In my 28.5 years as a technician, 10 of those years experience with Jags, the direct injection engines are incredibly difficult and time consuming to rebuild. I have not built one but, I’ve replaced many of the V6 & V8 DI engines. If I were you, I’d hold onto the valve covers, wiring harness, ignition coils and fuel injectors to sell. It is my understanding that the power train computer (PCM) can only be programmed to one vin and that’s it. Don’t take that as 100% gospel but, we had to replace one on a customers car with a new OEM PCM under advice from Autologic as a used PCM wasn’t going to work. I’ve broken a couple valve covers and fuel injectors trying to remove the injectors with the engine still in the car so I think you could sell those.
Old Aug 28, 2022 | 10:31 PM
awegrzyn's Avatar
Seems you are correct.
