XJS ABS Brake Parts- 89-94 - Good Used- Little Bit of Everything ....
For Sale
Brakes
  • Brakes - XJS ABS Brake Parts- 89-94 - Good Used- Little Bit of Everything .... - Used - 1989 to 1994 Jaguar XJS - San Francisco, CA 94116, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
  • Price
    $1
  • Location San Francisco, CA, 94116, USA
  • Condition Used
  • Compatibility
Make Model Year
Jaguar XJS 1989 - 1994
Description:
Selling a small collection of leftover XJS ABS brake parts from several 89-94 parts cars used for one of my projects. The donor cars were:
89 XJS coupe- 68k orig miles- engine trouble- stored in a garage for the last 5 years
90 XJS convert- good runner but had problems with brake actuator solenoids- other parts all good
94 XJS convert- good runner/driver- brakes worked perfectly (engine lost compression in 1 cyl).
RHD actuator- exact year unknown
Here is what I have available- this is all there is- nothing else. Many of these parts are hard to find in good used shape- all Posting here first for the Jag enthusiast community before listing on Ebay (at higher prices due to fees). Buy now and save $$$$$
ABS actuator assembly complete- 94 - ready to drop in and drive- perfect shape- fits 90-94 cars $600
ABS actuator assembly complete- 89- complete and in good cond- 89 models only-$450
Pump/motor assembly, no accumulator or switch- 1990- good used and works- tested- fits 90-94 cars- $250
Pump/motor/switch/accumulator assembly, newer accumulator- 1994- ready to use- fits 90-94 cars- $450
Pressure switch, 89 only, (black top_) tested good- P/N JLM1465- $150
Pressure switch, 90-94, from running driving car- P/N JLM1908 - $95
ABS ECU- DAC10056 (from 1994 car) worked perfectly- no issues- fits 92-94 models- $100
ABS speed sensors- rear- 89 XJS coupe- overall good- both tested and read correct 1100 ohms- fits coupe 89-93 and convert 89-91- P/N DAC6899 and DAC4840- sell as a pair- $100
Wiring harness-full wiring, front to rear- 89 XJS- P/N DAC5551- fits 89 models only- good to use to replace or repair a damaged harness $150
Wiring harness-full wiring, front to rear- 94 XJS- P/N LHC3410AB fits 92-94 models-good to use to replace or repair a damaged harness-$125
Actuator- XJS ABS RHD, exact year/condition unknown- sell as core to rebuild or for parts $50
All prices plus shipping. Located in the San Francisco area. Send PM for more info'
Old Jun 5, 2020 | 02:59 AM
JayeXJSC's Avatar
Default X
Xjs lock set.
it’s a long shot but are they available or do you have a set?
thanks
j
Old Oct 3, 2022 | 04:54 AM
Sachaf's Avatar
Default Abs dac10056
Hi
do you stil have :
thank you regards
sacha
Old Oct 3, 2022 | 04:55 AM
Sachaf's Avatar
Hi
do you stil have :
thank you regards
sacha
Old Feb 18, 2025 | 06:56 AM
GebrDeWilde's Avatar
Hi, we are interested in the following part: Pressure switch, 89 only, (black top_) tested good- P/N JLM1465- $150. Can you please contact us? Do you ship to Belgium? Thank you in advance.
Old Sep 9, 2025 | 04:17 AM
sleong66's Avatar
Default Part availability
Hi, is this part still available?
