XJS ABS Brake System - 89-94 Actuator, Pump/Motor/Switch, ECU, More; Works Perfectly
For SaleBrakes
Description:
Selling complete good used ABS brake system from a 1994 XJS convertible. Will fit 1989-1994 XJS models, coupe or convertible.
This is in a running and driving car and has been tested to work perfectly . Has been driven on the road and stationary- no issues. Brakes smooth and straight. System pumps up as it should and pump motor turns off; comes back on after 4 -5 pedal presses as it should. The accumulator (black ball) was replaced a few years back ( it was $400+, a factory part) which is key for the system to stay in good operating condition (you can tell it's new as it has the wide yellow stripe on top where all of the accumulators that came with the cars new had a narrow yellow stripe)l
The Jag engine is bad (low compression, but still driveable) so the car is being used for parts. Selling complete system-
1) Actuator assembly (the "master cylinder") with reservoir
2) Pump/motor/switch/accumulator assembly
3) Wheel speed sensors (4)
4) ABS system ECU
If you have an XJS with this system, you know how hard it is to find good parts for it, new or used. The accumulator is over $400 and the brake switch (alone) is over $600. The actuator and brake pump assembly aren't even available any more
Don't buy some unknown used unit that has been sitting in a field or on a shelf for years- this set works- no questions. This system is still in the car and will remove when sold.
Asking $995 plus shipping. Will not part out- all or nothing.
Located in the San Francisco area.
