1995 jaguar xj6 300
HI I HAVE JUST PURCHASED A 1995 JAGUAR XJ6. i LIVE IN NORTHERN CALIF. I HAVE WANTED ONE OF THESE CARS FOR SOME TIME. HAD IT ONLY TWO DAYS AND THE TROUBLE JUST STARTED THE GAUGES JUST STARTED TO GO CRAZY IT WOULD DIE ALL GAUGES WOULD GO TO ZERO AND DIE FOR A COUPLE SECONDS AND GO INTO LIMP MODE JUST BARELY GOING FINALLY GOT IT HOME AND PARKED IN GARAGE. TALKED TO A JAGUAR MECHANIC AND HE SAID FIRST THING IS TO CHANGE CRANKSHAFT POSITION SENSOR AND I DID NOW THE SAME PROBLEM OCCURS BUT GAGES ARE STEADY AND CAR STARTS AND DIES. I HAVE MEASURED THE GAP BETWEEN SENSOR AND IT IS .046. ARE THE SPEC. .018 TO .042 AND COULD THIS BE THE PROBLEM. I AM RETIRED AND WORK ON ALL MY CARS AT HOME HAVE AN OBD11 THAT REGISTERS OCCASIONALLY P01775, P0727. DOES ANY ONE KNOW OF A GOOD TESTER FOR 1995 JAGUAR XJ6 THAT WILL GIVE MORE INFO MAYBE CAR MD. THANKS IN ADVANCE FOR ANY HELP. EXCITED :icon_hyper: JIM / HAVE EYE PROBLEM CAN SEE CAPS BETTER. EYE SURGERY AND LENS IMPLANT AND 74 YRS OLD
Welcome to the forum Jim,
Good to have you here with us at Jaguar forums. I can tell you're excited from THE CAPITAL LETTERS. Follow this link XJ X300 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum to the X300 section for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues. This link https://www.jaguarforums.com/forum/g...oved-**-33347/ will take you to the thread on scanners. It has member's recommendations and also what to avoid. Remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details. You can also visit the US Western Region section by following this link Western US - AK CA NV OR UT HI WA ID - Jaguar Forums - Jaguar Enthusiasts Forum to find other members in your region. Enjoy the forum. Graham |
Good to have you with us. Enjoy the forum. If you haven't already done so you should add your car details to your signature to help others to help you. |
Welcome to the forum, Jim. Head on over to the X300 section and we'll get you sorted out. Search "instrument panel" over there and I think you may find some interesting reading. Crank sensor was a good call, as they are prone to failure and frequently give a bit of warning like that. Apparently not the whole problem, though.
welcome to the forum
Welcome!
Welcome to the forum.
Good to see you. The X 300 guys will get you going. |
https://www.jaguarforums.com/forum/a...ine=1355077469
Hey there and welcome aboard....... good to have you here with us here at Jaguarforums If you need any further help, please just ask Any useful site information you may need such as how to post pictures, edit signatures, add videos, using the search facility etc, can be found here within the following link Helpful_information Please also take the time to check out the regional section for your area! There are lots of members local to you with the same interests with info on local dealers and possible meets. Regional - Jaguar Forums - Jaguar Enthusiasts Forum I've manually upgraded you to Full forum access so you can better view the site and all its features Please Jump on in and enjoy the site................. :icon_beerchug: |
I replaced crankshaft sensor with lucas still misfire $107.99 -$20.00 online purchase =87.99 +tax autozone
key on connector disconnected pin 3-5.05v pin 2- 0v pin 1- 0v key on connector connected checked tps pin 2 -.56v closed throttle to 4.62v wot variable with throttle checked two temperature sw 1 pin temp sw water heated on stove normal temp .65k ohms to .09k to almost boiling 2nd temp with two contacts . Normal temp 2.75k ohms to.48k ohms almost boiling checked front o2 sensors heater elements seemed ok not open will check rear 2 o2 sensors tomorrow. Fuel pump pressure at 42 psi constant except when it misfires it drops 5 psi. I un-pluged the sensor by the throttle body and the engine ran a little smoother and would keep running it has 4 pins. Plug it in and it dies. No measurements on this one till i figure out which one it is. Any ideas or suggestions. What's next. |
map airflow sensor replaced and all ignition coils replaced fuel filter replaced
brake lites do not work. probably sw under dash defective cked all fuses will ck again. cruise control not working. turned off. going to replace two terminal temperature sw tomorrow. |
New 900cca battery. Keep it charged with 2a trickle charge.
Alternator belt was screaming today there might be a short in the alternator. Voltage output on gauges are about 13.5 v stays constant but could have a intermittent short in alternator. |
Why no reply does it take a year to get responses
:icon_special:
Many members check the Intro section. A lot will read them (your Intro has had 125 'views' as I write this) and several will post a 'welcome' in reply (as 7 members have done).
However, few members will then check back here again which explains why your posts listing progress haven't received replies. The 'normal' procedure is to start a thread in the appropriate tech section for troubleshooting progress and questions. I can move your posts #9, #10, #11 and #12 to a new thread in X300 section where members with the same model will see it and respond. Do you want me to do that or do you want to start a new thread there yourself? Graham |
Originally Posted by Big-D
(Post 780482)
TALKED TO A JAGUAR MECHANIC AND HE SAID FIRST THING IS TO CHANGE CRANKSHAFT POSITION SENSOR AND I DID NOW THE SAME PROBLEM OCCURS BUT GAGES ARE STEADY AND CAR STARTS AND DIES. ....but if replacing the crank sensor fixed it, you're lucky :-) Cheers DD |
(Post 783960)
Alternator belt was screaming today there might be a short in the alternator. Voltage output on gauges are about 13.5 v stays constant but could have a intermittent short in alternator. Cheers DD |
(Post 783954)
Do you still have the misfire? brake lites do not work. probably sw under dash defective cked all fuses will ck again. Brake light switch failures are fairy common. Easy enough to check with a meter. The original design was replaced with an update taht requires a silly-expensive adapter harness. A DIYer with a bit a creativity could fabricate his own adapter wiring easily Cheers DD |
Still misfire isolated alternator. Unplugged iac and misfire still but less but engine will continue to run. Going to ck measurements on iac.
Do you know what measurements should be? Replaced temp sw. Still misfires. Checking all grounds. Need to check all the front by headlamps. I checked tps with it unplugged and key on the pin 3 was 5.0v pin 2 was 0v pin 1 was 0.1v plugged it back in and pin 2 is now 4.9v i saw some where pin 2 unplugged should be 4.9v. Is this true. What is wrong . Cking all relays and blowing the contact out and putting gel to protect from water and other matter to insure good contact. |
Brake lite will diagnose later. Still misfires. Isolated altenator to see if it was introducing any thing into system and it is still misfire.
What does this harness accomplish
The harmonic balancer is on air cond. Air is off and screams a little and all belts are tight.
