03 S-Type Misfire
Old Mar 14, 2014 | 11:55 AM
Londonjagowner's Avatar
Default 03 S-Type Misfire
Cylinder 5 misfire on an 03 ST V6
The problem turns out to be the O-rings and and an ignition coil boot. How big of a job is this (time and complexity wise) and how much should I expect to pay (including changing the intake manifold gaskets etc)?
Thanks!
Old Mar 14, 2014 | 12:10 PM
QuartzSTypeR's Avatar
Not too difficult. If you are paying a shop, I'd expect somewhere around $300 for parts and labor.
Old Mar 14, 2014 | 12:44 PM
tbird6's Avatar
Your car is now 11+ years old. Miles?? That always helps too.
I would change all the coils and all the plugs if they have not been done already.
The 6 cylinder has its own unique problems with IMT valves and vacuum leaks. I would plan to do a major fix all at once. If not it's very common to keep losing one coil here and one coil there so you end up going back in several times when if you did it all at once you would be done!
Old Mar 15, 2014 | 07:05 AM
joycesjag's Avatar
Here are some prices and ideas from 2011:
https://www.jaguarforums.com/forum/s...tenance-49309/
aode06
Jul 28, 2023 02:26 PM
Clare Jennings
Oct 4, 2015 05:43 PM
reb1999
Sep 26, 2015 08:41 AM
