06 jaguar STR code P0174 Only
Hello Jaguar forums.
I recently picked up a 2006 Jaguar S-Type R after looking for a long time and I am really loving the car. But as of recently, I am throwing the code P0174 Lean Bank 2. I've read on the forums about the P0174 and P0171 codes caused by a vacuum leak. But I am only throwing the 74 code. I've also inspected the vacuum lines after reading another forum and they seem good to me. Sometimes it throws the check engine light and other times it's stored in pending codes. My mpg seems fair and the idle seems good too. My next guess is a bad O2 sensor and wanted to get an opinion from someone on here if they think that's what it can be. Also another question. Which side of the engine is Bank 1 and which side is Bank 2? Thanks. -Nicholas |
Use the search function of this forum as this topic has been discussed at length many times.
Check injector seals on Bank 2 for leaks. What are the STFT and LTFT readings for Bank 2? If the MIL is on, what are the DTCs stored in the system? Post them here. |
bank 2 is on the LH side of the car .
check your exhaust flange for leaks as its known to cause this issue too. other wise it would have to be the bank 2 blower to charge cooler rubber connection or the manifold gaskets under the charge cooler - or an injector issue , but i doubt it will be an injector or you'd have a misfire code as well. your best bet is to get your self an elm327 and monitor the live data . for fuel trims & o2 sensor function. there are some nifty tricks you can use with the fuel trim live data and a can of ether to find vacuum leaks . |
Originally Posted by Datsports
(Post 1782150)
check your exhaust flange for leaks as its known to cause this issue too. other wise it would have to be the bank 2 blower to charge cooler rubber connection or the manifold gaskets under the charge cooler - or an injector issue , but i doubt it will be an injector or you'd have a misfire code as well. your best bet is to get your self an elm327 and monitor the live data . for fuel trims & o2 sensor function. there are some nifty tricks you can use with the fuel trim live data and a can of ether to find vacuum leaks . https://drive.google.com/open?id=0B9...lZQbUlZTlk0X2M |
Check both banks in case it's close to also flagging P0171. LTFTs...
Yes, you can record fuel trim data using the Torque app - the purchased version - at least several years ago, the freebie would not give you fuel trims.
