Is amsoil 5w-30 compatible with the factory warranty?
Just want to make sure, because Jag recommended using only Castrol Syntec with the supercharged motor. I do not want to mess with a warranty problem if i ever need the motor replaced :icon_doh:. I'm pretty sure Amsoil is a true Group IV synthetic so i don't see how it would hurt the motor. Any suggestions?
I dont see an issue with it, as long as the oil was changed at the right times.....Best guess would be, cal the dealership and ask....I dont think they are that hardcore about it.....but never know....
I use Mobil 1 full synthetic |
I use Amsoil series 2000 made only in 0W-30. It far exceeds Jaguar requirements. No auto manufacturer can legally dictate that you use a certain brand of oil, however they possibly could have a leg to stand on if you use a different weight oil than recommended, but very unlikely.
weight rec. depends on climate, etc.. a 5-30w is recommended, not required. You might want to use a 0-30w or even 20w in Canada or other cold climates in the winter. Techs and people in those areas know what works best. As far as Amsoil, everything they put out exceeds requirements of just about any manufacturer.
Hey Brutal
what type of oil did you use on your car.. since we both are from Houston, i might as well follow your footstep. and have you heard the Jaguar repair shop called Lucas Auto Care? http://lucasautocare.com/defaultjaguar.php are they any good? i might need to bring the STR for a tune up or check up. thanks in advance |
Why not just take it to Brutal?
Originally Posted by Kapitan1975
(Post 285782)
Hey Brutal
what type of oil did you use on your car.. since we both are from Houston, i might as well follow your footstep. and have you heard the Jaguar repair shop called Lucas Auto Care? http://lucasautocare.com/defaultjaguar.php are they any good? i might need to bring the STR for a tune up or check up. thanks in advance WHAT SIDE OF HOUSTON DO YOU LIVE AND WORK??? |
Originally Posted by 08Z06
(Post 285713)
1) Some Amsoil products do not carry API certification. If you use them and things go badly, don't expect Jaguar to honour the warranty 2) There's no evidence that Amsoil (or any other boutique oil) has any tangible, credible benefits over the plain jane varieties. You might make yourself feel better by using them but your car couldn't care less. IBTL. |
If you wish to learn the facts about API certification check here:
http://www.synthetic-distribution.co...ification.html |
Originally Posted by Mikey
(Post 285875)
Two comments before things fall off the rails as they usually do with oil threads
Originally Posted by Brutal
(Post 285896)
they almost always want maintenance records, and if you DIY you better have receipts with a mileage log etc or that will give them a OUT
I use amsoil in the race car and the trans in the nissan. They exceed specs for both :)
(Post 285835)
WE HAVE 2 DIFF ENGINE, MINE IS SPEC'D FOR 20-50, YOURS 5-30 STAY WITH 5-30 YOULL BE FINE, JUST CHANGE @5K UNLESS YOU DRIVE SHORT DIST AND DONT EVER GET ON IT. THIS TYPE DRIVING SLUGGES AN ENGINE MORE THAN ANYTHING SINCE IT NEVER GET UP TO OPERATING TEMP FOR LONG. IF THATS THE CASE GO TO 3K.....ALLTHOUGH NOW EVERYONE IS GONNA WEIGH IN ON THE 'OL WHEN SHOULD I CHANGE MY OIL.....:icon_doh:
WHAT SIDE OF HOUSTON DO YOU LIVE AND WORK??? Brutal.. i live in the north... by HWY 249 and HWY 1960. i travel most of the time, spend more than 200 days last year on Hotel, plane and rental cars.... so i should be using 5-30w, would the mobil 1 full synthetic oil be good? thanks |
(Post 285924)
Brutal..
i live in the north... by HWY 249 and HWY 1960. i travel most of the time, spend more than 200 days last year on Hotel, plane and rental cars.... so i should be using 5-30w, would the mobil 1 full synthetic oil be good? thanks I received a PM with regards to my comments above (gee what a surprise) wherein the poster had misconstrued my statement as having had negative experience with Amsoil products. Here is my response: "No bad personal experience nor did I allude to such a thing in my post. As stated, there's just no advantage to it in 'real world' terms. I come from a lifetime career in the OEM engine business and have heard all possible snake oil pitches many times over. Engine failure due to supposed inferior oils is pretty much a myth. Going beyond OEM requirements is a waste of money. Using non-approved lubricants or parts can and will put the warranty in jeopardy." |
WELL IM NOT MIKEY, BUT SOME MAY DISSAGREE,:) BUT YOURE FINE WITH 5-30W
AND YES I USE SYNTHETIC. BUT I GET IT VERY CHEAPLY. IVE ALWAYS FELT THAT THERES NOTHING BETTER THAN REGULAR MAINTENANCE OF A VEHICLE IN ALL AREAS TO REDUCE LONGTERM COSTS AND IMPROVE RELIABILTY I received a PM with regards to my comments above (gee what a surprise) wherein the poster had misconstrued my statement as having had negative experience with Amsoil products. WASNT ME:) AND UNFORTUNATLY READING A OWNERS MANUAL IS A RARITY:icon_rtfm: <<<<NOT DIRECTED AT YOU KAP, I KNOW ITS EASIER TO ASK A QUESTION THAT FIND THE MANUAL AND LOOK IT UP, NO HARM NO FOUL. IF YOU WANT TO COME DOWN IDE BE MORE THAN HAPPY TO LIFT YOUR R IN THE AIR DURING A LOF AND TELL YOU WHAT I THINK ABOUT YOUR CAR FROM SOMEONE THAT SEES THEM DAY IN AND DAY OUT WITH AN UNBIASED OPINION AND YOU CAN AT LEAST BE INFORMED ABOUT YOUR CAR......FAIR :) DAMN STUCK CAP LOCK BUTTON |
:icon_doh::icon_hyper:
So i guess that i should not be using it then?
The Amsoil 5w-30? Kinda expensive (I guess) but should work fine in an S-Type.
I'd check it meets the jag spec but would expect it to. But... the SC engine is good, just give it any cheap decent oil meeting the spec and change it reasonably often - but not too often. Spend any money saved on other things or save it for a rainy day. |
(Post 286020)
(Post 285949)
AND YES I USE SYNTHETIC. BUT I GET IT VERY CHEAPLY. IVE ALWAYS FELT THAT THERES NOTHING BETTER THAN REGULAR MAINTENANCE OF A VEHICLE IN ALL AREAS TO REDUCE LONGTERM COSTS AND IMPROVE RELIABILTY I received a PM with regards to my comments above (gee what a surprise) wherein the poster had misconstrued my statement as having had negative experience with Amsoil products. WASNT ME:) AND UNFORTUNATLY READING A OWNERS MANUAL IS A RARITY:icon_rtfm: <<<<NOT DIRECTED AT YOU KAP, I KNOW ITS EASIER TO ASK A QUESTION THAT FIND THE MANUAL AND LOOK IT UP, NO HARM NO FOUL. IF YOU WANT TO COME DOWN IDE BE MORE THAN HAPPY TO LIFT YOUR R IN THE AIR DURING A LOF AND TELL YOU WHAT I THINK ABOUT YOUR CAR FROM SOMEONE THAT SEES THEM DAY IN AND DAY OUT WITH AN UNBIASED OPINION AND YOU CAN AT LEAST BE INFORMED ABOUT YOUR CAR......FAIR :) DAMN STUCK CAP LOCK BUTTON so i can't even check. Where do you think we can get a copy of owner's manual aside from ebay. thanks |
