Climate control module from xj8 swap out?
I went to the dealer today hoping to compare the XJ8 CCM with an S-type (non nav). I wanted to see if they matched in size, mounts and rear jack. He had no XJ8 modules. He added that although the S-types need replacing often he seldom sees that in XJ8's. They do look identical except mine is flat black and the XJ8's is glossy. I think I could swap the faceplates. Hoping that someone has actually tried this or maybe one of the Techs might know. There are several on Ebay for the XJ8 but none for newer s-types. They range from $70 to $150 compared to $1410 new.
Originally Posted by Dirk Bailey
(Post 260792)
Take a picture of the connections. Many vendors on Ebay will also have pictures of the parts. My gut tells me, if the connectors look the the same, they probably are. The other thing is to get the wiring diagrams for both and confirm the wires. |
(Post 260792)
George |
My CCM has a glitch. It infrequently flashes very rapidly but usually it operates normally. When it's flashing it still works fine. One of our fellow Jag forum members said he had the same thing happen to him he took it straight to the dealer and they told him it was about to fail and replaced it under warranty. My DCCV is dry, all vents are blowing the right temp. I have not pulled it out... I think I'll wait until I have a possible replacement. The only thing I know is it's totally random when it happens. If I restart the car it may be back to normal display. I've read Justin's fix (excellently done) on a bad circuit but I'm of mind to think that's directly related to a faulty DCCV. You guys are helping me work through this and really appreciate your time. Who knows, I may just try the XJ8 module (only an $80 gamble) but was hoping someone might know for sure. But if not I'll be the guinea pig on this and I'll document it for everyone. THANKS
(Post 260873)
You can try it and always put it back on ebay if it won't swap out. |
(Post 260873)
I'm with you guys. Thought I'd let this cook out there for a while in hopes that someone says "Hold on, it's not the CCM it's the finortner valve connection/fuse" or whatever. But the reality of the situation is it is likely the CCM, which is still working perfect.... 90% of the time. I give Jeff credit for this idea and I too think it'll work. But if any of you techs out there want to ask your parts guy that would be awesome. Keep on fighting the fight!
The electrical diagrams look quite a bit different to me. Did you check them?
I have not checked the elec diagrams... so thanks for the heads up. Not sure I'll know what I'm looking for. IF the rear jack matches and has the same pin configuration what do you think of our idea? I have Jtis to 2004 are those the diagrams you speak of?
If I were in your situation I'd check the diagrams carefully and if they're different I'd abandon the idea. I had time for a quick glance and they immediately looked different. (If you don't want to check yourself, that's OK by me.)
Originally Posted by jagv8
(Post 261132)
Couldn't even see the DCCV. Pinouts look different. Really, anyone who has any leanings in the direction of the OP may as well check first rather than buy anything.
(Post 261148)
Are the diagrams in Jtis, being that they're 2004, the diagrams you're refering to?
Yes and on http://www.captainjaguarscathouse.co...trical_Guides/
The CAN is different, too, by the look of it. Twin on the XJ and single on the S. If you're good at making up cables, it may work. If the modules are internally the same. I cannot see why they would be but it's possible. |
(Post 261179)
Yes and on www.captainjaguarscathouse.com/Electrical_Guides/
The CAN is different, too, by the look of it. Twin on the XJ and single on the S. If you're good at making up cables, it may work. If the modules are internally the same. I cannot see why they would be but it's possible. OK, I really need to stop being distracted and get back to work:icon_hyper: I just like this stuff... Think it's neat... |
Right now I have time on my side because it's still working. I'll keep my eyes open for a used newer stype CCM on ebay (there are many for the older stypes). You guys rock!
Originally Posted by JOsworth
(Post 261198)
Interesting thing is the newest XJ8 electrical diagram on that site is the previous generation and not the 2004 to 2010 car that we are talking about. Need to look in JTIS. They should have the newer car's on there.
If it can be made to work (using own-design connectors etc) and if the XJ doesn't blow its module due to DCCV, then it would be useful. |
Decided to take a more proactive approach, rather than wait for my CCM to fail. I ordered a new Bosch heater valve (DCCV) on Autopartsworld ($82). Even though my DCCV is dry, one thing is apparent if you spend any time on this site they fail and they fail often, and not always in the same way. Thought it could possibly be causing my CCM glitch or perhaps prolong my CCM from failure. The fact that Jagv8 didn't even see a DCCV on the XJ8 wiring diagram lends itself to my dealer parts guy's statement that he "seldom sees CCM failures in the XJ8". Also, I noticed on Ebay today a later model s-type CCM for $400 plus $100 exchange. In the ad they speak directly of heater valve failure AND their part is warranted for one year only if you show proof of heater valve replacement prior to putting in their rebuilt CCM, interesting? It appears the vast majority if not all CCM failures are caused by a short on the circuit board brought on by valve failure. So if/when my CCM fails I'll try Justin67's fix first. I know several of you have pointed me in this direction earlier but sometimes it takes me a little longer than others. Thanks.
(Post 261411)
I, too, am curious as to why identical looking units may be different. The controls and display are exactly the same. I will keep checking in on this... |
