Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   S-Type / S type R Supercharged V8 ( X200 ) (https://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-x200-15/)
-   -   FUEL COMPUTER DATA ERROR (https://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-x200-15/fuel-computer-data-error-8917/)
OneSource Oct 29, 2008 08:38 PM
Hey guys, just started her up tonight and a few things happended. first off the information display read FUEL COMPUTER DATA ERROR. the ac is locked at 73 farenheit and if I try to change it, it will automatically switch back to that temp/ setting etc. the blinkers are also clicking fast as if one were out, but they both function correctly on the outside. the fuel gauge also is at E even though I have a full tank.drives fine though. anyone experiece this and or have a diagnosis?
Thanks in Advance!
harounq21 Oct 30, 2008 09:12 AM
RE: FUEL COMPUTER DATA ERROR
disconnect the battery for 20 min. See if the problem persists.......
OneSource Oct 30, 2008 01:15 PM
Thanks for the reply harounq21. I let the car sit for a few hours then started it up and everything was normal. Id be curious to know the cause of this.
harounq21 Oct 30, 2008 07:19 PM
sometimes the computer needs to be recalibrated.
whitestype Nov 3, 2008 08:08 AM
was just wondering if any1 thinks you should disconnect the battery every once in a while to recalibrate the computer?if so how often and has any1 ever done that?
Aeneas Nov 4, 2008 11:52 PM
ORIGINAL: whitestype
My very first post on this forum around 3 months agowas about how I fixed the mileage readings on my car by resetting the computer, by turning off the battery for a whileand then reconnecting the battery.
Seems like others are adopting this method of fixing intermittentcar computer errors, rather than allowing the dealership to steal their $1500 replacing the computer.
sbishop Oct 21, 2009 01:20 PM
I have had a similar problem driving along motorway and all dials set to zero and revs stayed high, message "Fuel Data Computer Error" shows. Recovery truck got fault code 1638 and filed down earth points,.. car worked. One week later same thing happens, garage take it in and find one corroded earth point and one snapped on the battery tray. Replaced today,.. and guess what happens driving home? - yep same thing.. am seriously hacked off.
About the disconnecting battery thing,.. I don't know much about cars but I know this can't be the best idea! Also fault codes are stored in the computer until reset.
209jaguar209 Oct 3, 2010 11:58 AM
Fuel computer data error
hi, my s-type started doing the same thing,,,did anyone get it fix?
JagV8 Oct 3, 2010 12:26 PM
Looks like no-one affected ever posted details of their car or posted more messages. You could :)
It's probably a battery that's failing but without more data that'll stay a "probably".
209jaguar209 Oct 3, 2010 01:45 PM
i know..i tried it already,and its the same,,i changed the fuel filter too...its been 2 days,,im going nuts!! hahah..i hope its nothing big
JagV8 Oct 3, 2010 01:58 PM
... Looks like no-one affected ever posted details of their car ...
Leedsman Oct 3, 2010 03:54 PM
These peculiar and random "computer errors" can be down to a bad battery; there have been lots of posts on this one. My last one suggested strapping a good second battery with jump leads across the vehicle's own battery, propping it up with concrete blocks in the boot/trunk. Then going for a drive or two to see if problem fixed. The Jag. ECU's are known to be sensitive to battery voltage. During cranking, the voltage of a good battery i.e. one with enough amp/hours, shouldn't drop below about 9volt. The heavy current of 600amps or so is also slightly 'impulsive' due to the brushes in the starter motor and their contact with the commutator. These "spark" quite a lot although you can't see it of course. Sparks and microprocessors? BAD NEWS!
Leedsman.
JagV8 Oct 3, 2010 03:57 PM
He says he's changed the battery.
Maybe he'll post more data.
209jaguar209 Oct 3, 2010 03:58 PM
thats what i thought at first, so i went and bought a new battery, but it keeps doing it
Leedsman Oct 4, 2010 03:56 AM
There's a recent post about going through the heavy current battery circuit, it's not simple, there are 'protection devices'. Any minor corrosion anywhere in securing nuts etc. can cause subtle sparking during cranking which could affect the microprocessors. You're getting in the long grass now, can't help much more.
Leedsman.
mcadame Nov 28, 2010 03:19 PM
FUEL COMPUTER DATA ERROR (diagnosis)
:icon_hyper:My 2001 Jag S-type would'nt start and on the dash said (FUEL COMPUTER DATA ERROR) so i tried to disconnect the battery, didnt work. My nieghbor who is an engineer came over and made a diagnosis and said maybe a (DIODE) needs to be replace $ 8 peice..quantity (2).......... called Jag dealer took acouple of days but in the mean time i would pull it out of its slot and put it back in and car would start.........These Diods are located, one in the engine department inside fuse box and one in the trunk in the fuse box next to the battery.....(DISCRIPTION) Black 1/2" long x 1/8" wide................ have a great day!!!!!!
Leedsman Nov 29, 2010 03:42 AM
FAO. Mcadame, can you read off the number on said diode and let me know? Then I can tell you what type of diode it is (silicon, shottky, zener, etc.) and if it's in my books its rating (PIVvolts, current etc.). Then I might guess as to its purpose. Diodes always have a ring printed on them if they are cylindrical in shape indicating polarity.
Often they start 1Nxxxx. Such semiconductors are almost always very cheap.
Leedsman.
p.s. When such diodes go wrong, they always go deadshort. A common ohmmeter will test them. If not soldered in, subtle corrosion is a possibility on leadouts.
thedoc5 Feb 24, 2011 09:23 AM
Hey guys, Ive read the old post about disconnecting the battery which I plan to do, but I also have with this problem at the same time the sunroof quit working along with the rear windows and the park lights are remaining on long after I have left the car. Are those related and will the battery disconnect also solve this as well.
austinmartus Feb 25, 2011 07:17 PM
FuEl data error usually is a problem with the fuel level senders.
thedoc5 Feb 25, 2011 08:44 PM
fuel data computer error
Austinmartus
Thanks for the reply however I have several other problems with the fuel issue. I have disconnected the battery and it worked for a short time but the problem is back with a vengence. Now the lights dont work properly, the turn signals blink fast and dont work in the back, the windows are not working properly as well as the sunroof.
I think if is a computer issue and i need to know which and where to look. One mechanic said it is the instrument panel and may need to be replaced.
2000 jag s-type
© 2026 MH Sub I, LLC dba Internet Brands
