Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   S-Type / S type R Supercharged V8 ( X200 ) (https://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-x200-15/)
-   -   Gauging Interest: Killer Chiller (https://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-x200-15/gauging-interest-killer-chiller-41805/)
Mafioso Sep 7, 2010 01:41 PM
I spoke with Joe at Kincaid Performance and they are willing to work with us on a killer chiller setup for us.
Its $750 including everything
$650 if we can get 10 people in.
Kit includes:
KC heat exchanger.
New A/c lines
New stainless steel couplers.
All needed brackets.
average intercooler fuild temps should drop down to 60-70's on a hot summers day should see IAT2 temps in the 80-90's
vance580 Sep 7, 2010 08:29 PM
I'm a little new to killer chillers. How does this setup work I see it comes with A/C lines. So does it tie into your A/C system to use the freon to cool the air through the intercooler?? I'm just curious how this works. Would this pretty much eliminate heat soak???
Jaxkr Sep 7, 2010 08:38 PM
I have a Killer Chiller installed on my 2000 XKR & can attest to the fact that it really works. If I let my car sit & idle with the hood open on an 80 degree day for more than 10 minutes I can actually see the charge coolers start to sweat from being so cold. On my car I run the coolant thru 1 charge cooler then the other (as per Rocketsports) & moniter the coolant temp as it exits the second cooler, this way I am seeing the coolant at its highest temp. When sitting in traffic this summer the outside temp gauge on the dash showed 102 & the discharge temp was app 80. I was shocked to see how low the temp had gotten, once you start to drive in the hot weather the temp will rise to app 90 & go much higer under hard acceleration as high as 150 under 18 psi of boost, reaching speeds well in excess of 100 mph. The amazing thing is how quickly it will cool the charge temp as soon as you back off the throttle I watch the temp go right back to 90 in a matter of minutes. The best thing about the chiller is you never get heat soak when sitting at an idle, & your car runs like a cool fall day all summer long. You will find Joe is very knowledgable as well as helpful. He will go out of his way to make sure you are happy. If you would like photos of my installation I would be glad to send you as many as you would like. You are probally better off just buying the kit yourself as trying to find 10 people may not be as easy as it sounds. Also plan on your car being apart for 7-10 as you will need to fabricate a few parts. I eliminated the heat exchanger & installed an aluminum tank between the charge cooler & the chiller as well as an isolated coolings system with 2 pumps & a seperate resevoir. Best of luck
Riski Sep 7, 2010 11:44 PM
If it is not that bad of a install I am game!
Count me in, would like to see some more details on this....
Pics anyone? Actual tested results...
Riski Sep 7, 2010 11:51 PM
http://www.killerchiller.com/index.html
I like what I am seeing on his site
Mafioso Sep 8, 2010 12:13 AM
Thanks for the link Riski and the testimonial JAXKR. I've been talking to Joe and doing alot of research. We should except to see "an addicental power gain" and this is what intrigues me the most, accidental by the fact cooler air means more power. Joe said the new jaguar kits should be 4-5 hour install including recharging the ac. He has worked with a few s type R owners and refined everything.
He said he may also include a drag upgrade if we are intrested. The drag kit is basically a bypass to the cab evap focusing all the freon on the heat exchanger for the IC dropping temps by another 15-20 degrees when combined with industrial R12e.
When we were chatting today he was telling me in his test bed aka drag mustang running a procharger and 20psi (forgot to ask what size procharger) his charge temps do NOT hit 80 degrees in the NM 115 degree heat.
Mafioso Sep 8, 2010 12:17 AM
Here is a video
http://www.youtube.com/watch?v=73Ql84-iz6I&sns=em
Sent from my iPhone
Riski Sep 8, 2010 12:42 AM
http://www.youtube.com/watch?v=1OLmZ...eature=related
Im down for the drag pack......
How often do you have to re fill the freon?
Jaxkr Sep 8, 2010 05:46 AM
The system is sealed so you just use your a/c as you normally would. When I spoke to Joe the bypass system would bypass the evaporater, hence no in car cooling. I very much doubt the install will take 4-5 hours as nothing aftermarket just bolts right into a Jaguar, plan on at least 8 hours. The increase in power is more is more a decrease in your power loss due to heat, think of how much better your car runs on a cold day. I also purchased the commercial freon at Joe's recomondation but have yet to install. This should lower my cooling temp further which will also increase my cabin cooling. I will post photos later.
Mafioso Sep 8, 2010 08:38 AM
Well I guess the install time is all relavant to how you prepare.
I've removed the bumper cover on my other S-Type once so I know where all the bolts are.
I replaced the a/c comp on my other one as well.
Having all the proper tools all set ready to go also helps.
and most important, when you do something like this read the book forward backwards, sideways, upside down, right side up, inverted, and when your done do it again in reverse order. lol
Riski Sep 8, 2010 11:21 AM
I would love to see a dyno graph before and after....
Mafioso Sep 8, 2010 12:01 PM
Sure coming right up!
found one.
http://www.killerchiller.com/kwiksdyno.htm
Riski Sep 8, 2010 02:40 PM
Yea I seen that one last night....I meant for a STR.....Might have to do it and be the example again :D
You have to have your a/c on for this to work correct?
08Z06 Sep 8, 2010 11:42 PM
I am interested as well, i would totally be down for that if it works
Mafioso Sep 9, 2010 01:00 AM
Yea ac has to be on to cycle the compressor which is fine by me since I leave it on auto all the time.
08Z06 there's no if it works lol search on the lightning forums there are people that have been running them for a long time.
So looks like this would make 3 of us. Joe said worst case senario he will give the discount with 8 people STR,XKR,XJR,XFR mix and match lol
There has to be 5 others we can get in on this.
BTW KP has non supercharged applications also ;)
No I'm not affliated with just want to get it asap and would love to get it a little bit cheaper
flsupraguy Sep 9, 2010 05:13 AM
I thought this was an interesting read.... https://www.jaguarforums.com/forum/s...ad.php?t=39419
Mafioso Sep 9, 2010 07:08 AM
Very interesting indeed until you get into the fine print of the system. The heat exchanger is actually "tuned" for the application.
with an engine this expensive I'm not going to be the cowboy and start playing HE sizes I'd rather go the path that's proven.
Panthro Sep 9, 2010 08:04 AM
If this system works on Mustangs & Lightnings, then why wouldn't it work on the smaller displacement engines in the Jaguar? I doubt that your going to over-chill your coolant with this thing.
Mafioso Sep 9, 2010 08:49 AM
My point was that if you get the size of the heat exchanger wrong you have the potential to do damage. Either in the form of internal engine damage, blower damage, a/c compressor damage.
Joe has done the "experimenting" for us. He is doing another STR now when I talked to him he let me know he has done a few, but the kit is not on his website due to the rarity of our cars but since has been getting more inquiries he is going to add it on there.
Riski Sep 9, 2010 10:10 AM
Have him do a before and after dyno!
© 2026 MH Sub I, LLC dba Internet Brands
