Help dead battery
hi, i didnt put the battery on a trickle charger, ive not started it for a month,,, now the battery is dead, how do i open the trunk/boot? i know there is a post in the passenger wheel well but its a PITA,,, i mean thats really dumb to put it there...anyway,,, is there a way to open the trunk? thx
Use key in lock.
You'll kick yourself when you finally notice the boot lock!! Under the J A G U A R, I think near the U. Worth lubricating & using at least once a year, so it works when you need it. |
Originally Posted by Injekter
(Post 1207841)
thank you.... im going to go home and find the key hole,, i seriously stared at the trunck lid ans saw nothing......: 0 if not that alternator idea is awesome
Also, there is an emergency battery jumping terminal under the lining of the passenger side front wheel just forward from the door.
But try the key, first... ;-) ================================================== Jaguar: Grace, Pace, and Space - Sir William Lyons '08 Jaguar S-Type 4.2 "Satin Edition" |
Use extreme caution if you jump it off the alternator. There is a reason Jaguar put the post in the wheel well and not on the alternator. They are not cheap to replace.
boot open
no I should have been a little clearer you are not jump starting the car ,connecting only to get boot open .No engine should be running at all ,just power from doner battery to open boot ,..
thx all, i did find the keyhole.... its up underneath to one side,, i guess one must remember that it doesnt look like a traditional key hole as the key is not a traditional shape. i just put up a new post... battery is charged all is running, but the check engine light is now on.....
(Post 1209758)
That is because your battery was low and many components rely on it. You will have to take to an Autozone or O`Reily and they can test it with a code reader and clear those caused by low battery. Bought my car a month ago and the battery was dead at the dealer, had the same problem with check engine light when they got it recharged. New battery to, they think someone looking at it left a light on. Went and bought my own code reader after getting home. |
