Help pulling rear hub off
Hi all,
Just wanted to confirm what I am doing is correct. Here is a pic and I followed the JTIS instructions. I have the puller attached as you can see and want to confirm I just keep tightening that nut attached to that puller and the hub should come off, correct? Using my breaker bar to turn that nut that pushes against the rod in the middle of the wheel causing the hub to pop off? It states in the instructions to pull the wheel hub and then take that nut off the upper arm to complete the disassembly. Am I doing this the right way? It did state to remove the brake disc but not sure how to get that off. Also that nut holding that upper arm on, is that 18MM? Any help appreciated. http://imagizer.imageshack.us/v2/800...661/LS19wJ.jpg |
I don't think you can remove the axle with the top ball joint attached? Not enough wiggle room.
Is the axle moving at all? . . . |
Hi and thanks. Yes the axle is moving. It shows on JTIS to remove the hub and then take that last bolt off holding that upper arm. I agree, I would think it can't happen that way but in the JTIS it shows a picture with the axle out or apart and that nut still attached and then instructing to take it off. Problem is with that nut where it is located (if you look at that first picture, you can only get an open end wrench on it the way it is so I guess if you pull the wheel hub you can then reach it with a socket. And not sure what size but thinking 17 or 18 MM.
My problem is having a hard time just getting the brake disc off. Rusted on I guess. Here is that picture Gus. http://imagizer.imageshack.us/v2/800...661/DRVMhs.jpg |
Here is that page on JTIS. See how it looks like it is pulled apart with the axle hanging and that nut is still attached and stating to remove it.
http://imagizer.imageshack.us/v2/800...661/d78DZC.jpg |
Hi Gus,
You need to remove the rotor (mallet on each side) even possibly some taps of a hammer on the rotor where it is mated (in between the lugs) to the front side to the hub assembly. Then you must disconnect that upper control arm ball joint from the hub assembly before attempting to pull it. I believe it's a 17MM nut on the ball joint. It's tight in there - use vise grips to grab the bottom of the bolt while you begin loosening the nut. Once you have this done - the hub (with the removal tool) should pop right off. Hope this helps. Thanks - Anthony |
Originally Posted by Amadauss
(Post 1118784)
I have had the rotor get really stuck too so use a dead blow hammer if you have one and give a good whack!
Well did you get it off yet?
Tried a couple of whacks and nothing so sprayed it up a bit and thought let it sit over night in some heat (heated the garage up a bit) and go to it in the morning. Will take that nut off first, thanks abonano.
Thanks everyone of the help. Will take some pics for a thread and you Gus. |
Originally Posted by abonano
(Post 1118872)
Gus, don't read into the picture. Removing that nut is step #11 - then removing the hub assembly is step #12
I would have thought so also about taking that nut off first but here is page 6 from those instructions and it looks like they are showing that nut coming off after the hub assembly has been pulled. That has me stumped also abonano. But it clearly shows the axle out of the hub with that nut on the upper arm still attached in the picture. Maybe an error on JTIS directions. http://imagizer.imageshack.us/v2/800...538/EhCDpQ.jpg |
Yes, I would agree - sometimes the pics just reference the item (hence the arrow) I replaced my rear hub bearing and for sure I removed that upper control arm/nut from the hub assembly before attempting to pull it. The hub assembly came right off.
Also don't let the half shaft hang after getting the hub off. (Sorry for referring to you as "Gus" before - long day) |
No problem, I have been called worse then Gus before :icon_lol:. Sorry Gus. And I think you posted in another thread about using a hanger to hold on to the shaft to keep it up. Its getting that 17mm in there and getting that bolt off that is a bear. Not a lot of room to move around. Thanks for the help.
(Post 1119093)
Your killing me!
(Post 1119093)
Had to go out of town so let it on the jack stands. Back home and started over trying to take that brake drum off. Still no luck. I even put a screw driver between the slots on the drum and then banged away at it thinking maybe that would force it off. I probably should have left everything connected with the other stuff to hold the wheel in place and then tried the drum first.
Should I try heating it up? Any thoughts? Or just keep whacking away at it. Thanks |
You should still be able to remove the hub w/ the rotor attached. Then try to get the rotor off the hub. If the rotor is seized on the hub when you do get it off it may be worth changing it out (I typically change rotors in pairs)
Another thought - you can try and get penetrating oil between the hub and inside part of the rotor. A torch might be helpful at this point also... |
When I pulled the axles from my s-type, I took off the rotor, took off the axle lock nut, put on the hub puller, sprayed penetating oil down the side of the axle shaft, pressed the axle out of the hub about 1/2", then removed the upper control arm from the hub carrier. I also removed the toe rod bolt so the whole hub carrier can rotate downwards. With the hub carrier loose, I was able to continue pushing the axle out of the hub, eventually it was free enough to rotate the hub carrier down and came free from the axle. For me, pulling the axle out of the differential was a real PITA! I couldn't get it to pull out for the life of me. Took a couple hours and a lot of swearing before I was able to it it to pull out.
Originally Posted by Tijoe
(Post 1124121)
I usually can pop out the axles with two flat blade screw drivers but if not I do have a slide hammer attachment that works well.
https://cimg5.ibsrv.net/gimg/www.jag...35e08896b5.png . . . |
Thanks for the help and suggestions everyone. Went on you tube and their are a couple of videos with some good suggestions also to pulling off the rotor. Just do a search on you tube and it comes up.
