Be aware that the self test for the evap system only occurs when the tank is more that 1/4 but less than 3/4 full . When I was chasing the same code, I could fill the tank, reset the codes and drive about 150kms (numbers of days is irrelevant) before the CEL came on again.
Originally Posted by Mikey
(Post 674287)
OK I spoke too soon.
The code came on this morning and now its P0456 (very small leak) So I guess I am back to square one going to check the canister in the engine compartment any other suggestions? I have been through a lot of threads and there doesnt seem to be a common denominator as far as this code goes. Smoke test yes/no? Dean |
Yours has extra parts that aren't on the earlier cars so you could be pretty much a pioneer in terms of posting it on here. Didn't one of the techs (xjrguy? Brutal?) mention some of this?
Yes Jag I have read about the "extra parts" in the 07' and thanks to you for that!
So I will start at the EVAP purge valve/canister which seems the most common and go from there. |
Originally Posted by devo357
(Post 675047)
The code came on this morning and now its P0456 (very small leak) So I guess I am back to square one going to check the canister in the engine compartment any other suggestions? I have been through a lot of threads and there doesnt seem to be a common denominator as far as this code goes. Smoke test yes/no? Dean Brutal suggested that with his experience the problem was probably the gas tank O ring seals on the top of the tank sender, I could smell fuel at times from the rear of the car. They did a smoke test and said it was inconclusive, I showed them the message from Brutal, reluctantly they agreed to change the O rings (not really a big job) I don't know why they didn't just do it in the first place. Anyway, this cured the problem and no more codes. It has been three months and it has not returned. The smell of fuel also has gone away. I think the fuel smell was around for quite some time before the code was thrown only not very strong, I guess when the O rings worsened the smell got stronger and the code appeared. Thanks again to Brutal, |
Ok thanks I will add that to the ever growing list of things to check lol
I know this is a year too late, but if you see this, let us know it went and what eventually fixed it.
I've got the same issue and have had it for 3 years. We don't have inspections in Florida so I only start working on when the light bugs me, and I don't don't drive it as much anymore either. |
Sorry after I replaced the gas cap the code did come back I cleared it and it stayed off and has not come back. I was headed in the direction that brutal had pointed bit I never had to go there the code has not returned.
Glad ya got it fixed. I saw you changed the cap once and it came back. Did get another one and the second worked?
Originally Posted by hollywooddippa
(Post 978674)
Ha ha, that's funny, cause that's actually my next step on the list. Looks fairly straight forward. I'm going to pull the seat and take a couple pictures of the rings and see if the tool room has something I can check out for the weekend.
Did you replace both of them? Have you ever bought from a company called jagbits? |
No same cap I just cleared the code one last time and that was it. I think the code may have been stored from before I replaced the cap and popped up almost immediately after I changed it but again I think it was going to pop up anyway cap or not and after clearing it all was good.
(Post 979063)
(Post 979063)
