Jaguar s type r heads
Subscribe
May 18, 2018 | 03:32 AM
New to the thread!
Has anyone ever done the heads on a 2003 jaguar s type r? Debating if it's above my level or not. I'm getting a bunch of oil when I looked into the spark plug holes. Also debating on while I have it off what I should replace just in case other than the belts and stuff like that. 160k miles by the way.
thank you!
Reply 0
May 18, 2018 | 04:52 AM
you are talking about cam / valve covers not heads .
there is a big difference !
cam cover gasket replacement is an easy enough task .
nothing inside should need doing bar spark plugs .
Reply 0
May 18, 2018 | 08:22 AM
+1 on cam cover gaskets and spark plug boss seals being the reason for the oil leak(s).
Make sure you thoroughly clean each spark plug well and coil unit if oil is present to prevent misfires.
Reply 0
May 21, 2018 | 09:49 PM
thank you guys for the info!
Reply 0
Subscribe
Currently Active Users (1)
