please help me.
please if anyone knows what that means I will be very grateful.
Panne stop gauche /??????????? sajaa01p53fm67589 jaguar stype 3.0 v6 2002 |
It means your left hand stop light is bust - in French.
Where are you ?? |
I'm from Armenia, the car was sent from France.
replace the lamp? |
Yes.LH is your left sitting at the steering wheel BTW.
This isn't a model I know about but it might be possible to change the display language - an STyper will no doubt help soon. |
Does your car have the touchscreen?
You can change the message center language:
Ignition Key set at "II", press & hold the "mls/km" switch on the trip switchpack. 1st language displayed is what it's set to. Press "mls/km" switch repeatedly until the right language comes up. Then press the "A/B" switch. New language should be displayed after about 3 secs. Then press "Clear" to get back to normal display. Yes you should start by changing / checking the bulb, |
It's quite easy to change the display language, the instructions are in the owners manual. Not sure if Armenian is one of the choices but there's two versions of English available.
I again have to laugh that the word 'stop' is used in France whereas it's been banned from public usage in Quebec and the less correct word 'arret' has been substituted. |
Originally Posted by Michael Star
(Post 642008)
Thank you all very much ..
I'm pretty sure the touch screen and message center languages are two different settings.
Are they? I might have to try that at home. I thought it was all the same.
(Post 642118)
Originally Posted by Mikey
(Post 642017)
I again have to laugh that the word 'stop' is used in France whereas it's been banned from public usage in Quebec and the less correct word 'arret' has been substituted. well... having lived in both countries (France and Canada) I can assure you that what they speak in Eastern Canada is as much "French" as a vintage Fiat is a Ferrari. Just because there are some parts (words) in common does not make them the same (language). |
Originally Posted by McJaguar
(Post 642152)
Sorry for the hijack. |
Originally Posted by Norri
(Post 642016)
Just figured it out. You have to push and hold the mls/km key down BEFORE you turn the key to position 2. Thanks.
| All times are GMT -5. The time now is 01:19 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
