S Type R- aftermarket wheels- 19's or 20's?
Hi guys. As you know two of my wheels are screwed and 1 tire is shot. I'm thinking of going with a set of Stern St11 wheels. they're dirt cheap and look okay. The question is, should I go with 19's or 20's? I have lowering springs on my car. I will keep the staggered setup with 245's up front and 275's out back.
Photos of cars with 19's or 20's would be greatly appreciated!!! |
3 Attachment(s)
Personally, I think the 19's are perfect, but here are some of each.
19's Attachment 172909 20's Attachment 172910 Attachment 172911 |
I think 20" would look too big and the lower profile tires might hurt the ride comfort, but that's just my opinion.
Originally Posted by phaelax
(Post 337513)
The photo above is awesome. That car is the same color as mine too. That looks perfect. Now to decide on silver alloy colored wheels or black with polished lips. My windows are tinted like that car's. What specs/offsets do I need to buy? Stern make an 8.5 and 9.5 in my size so I'm in luck there. I just need to get the offsets straight. |
crap, they only make the st11's in 18"X8.5 in a 5x108. Bummer.
However, I just called a wheel place and they said that they would re-drill the holes to work with my setup. I guess they would get a 5X112 and move the holes 4mm some how. So, for $100 they'll do this. |
anyone know what offsets I need on a 8.5 front and 9.5 rear?
That STR with the 19" looks sick! Now aftermarket wheels are on the list!
I googled it for you and found this website... Wheel Fitment.eu PCD Jaguar S-Type - the largest online database with PCD, Offset and Center Bore date for almost every car
if you find another that says the same, it must be true! :) You could take a digi caliper and measure it yourself...only sure way to know, right? |
1 Attachment(s)
I say go with the 20's :icon_wink:
Not b/c I have them on my STR that is already lowered by Arden springs :icon_rolleyes: https://www.jaguarforums.com/forum/a...3&d=1302929728 |
bummer, the pic isn't working...
Originally Posted by qwiketz
(Post 337535)
(Post 337660)
Take care. :icon_bike: |
Jag79 Hey, that looks great! I have the same year and color and now wish that I would have gone that route when I replaced my tires recently. Lowered and 20's...great look and it fills the wheel well gap nicely....any clearance issues at all? Do you have any other performance mods?
Originally Posted by SCAATY
(Post 337791)
As for clearance issues and ride comfort, no problems at all(knock on wood) :icon_teeth: Having the Arden springs over the H & R springs gave it the perfect clearance and covers the wheel well very nicely when lowered with the 20's since H & R drops it down a little more lower. Take it easy bro. |
Originally Posted by pokey
(Post 337665)
What/where is the shop that will do the re-drill for you?
I am about to buy these 19" Coventry Hornets:
http://www.buywheelstoday.com/images...cts/L_4652.jpg They are made specifically for Jags |
Originally Posted by 08Z06
(Post 338129)
http://www.buywheelstoday.com/images...cts/L_4652.jpg They are made specifically for Jags Take care, George |
Originally Posted by h20boy
(Post 337591)
if you find another that says the same, it must be true! :) You could take a digi caliper and measure it yourself...only sure way to know, right? It says the s type is 50mm offset. Is that the same for the s type r or does it not matter? I just need to figure this out and then I have to figure out what is the best fit. |
Alright, so I looked into this a little more. I found on one website the specs for the S type R:
2004 Jaguar S-Type R Bolt Pattern: 5x108 Center Bore: 63.9 Hardware:12x1.50 Lug Offset: Front: 34-42mm Rear: 40mm However somewhere else I saw that the offset listed at 60mm. And on the coventry website, I saw this: front 42mm rear 42 Should I go off the coventry website since they market wheels specifically for our jags? Also, update... I found my wheels in a 19" 108 pattern, but only in the front size: Stern ST11 Hyperblack Wheels 19x8.5 Boltpattern 5x4.25 (5x108) Offset 38 Hub Bore 73 Partnumber ST1185950838HB they do have the 5X114.3 in 19x9.5" with 48 offset, but I'll have to have the wheel bolt pattern modified to 108 from 114.3. They make a 5X112, but it only has 25 offset. So that's where I'm at currently. This is kind of a pain to figure out but it should be worth it in the end. |
I forged makes rims to order that fit the 5x108 bolt pattern of the Jaguar. They're cheaper than HRE's and exceptionally good quality
iForged Performance Wheels - The next generation in forging technology |
