S Type Suspension Explained in Video! FAQ
Check out Sam's 10 minute video where he explains the details of a Jag S type front and rear suspension, what goes wrong and how to fix it.
How To Check Jaguar S Type For Clunks, Rattles, Noises - YouTube |
Good stuff - thanks for posting it....
1 Attachment(s)
Great video if the front lower ball joints are wornout can you press in new ones or do you have to replace the whole nuckles?
Great video. Someone needs to figure out and post the source for the lower strut bushings.
Originally Posted by Richard from Fraser Valley
(Post 505464)
Originally Posted by qwiketz
(Post 505569)
If this source works out this is a great piece of info have here!! |
Just remember that lower ball joints are only available for the Lincoln LS and the early 1999-2002 S Type. Also you need to know if your car has 14mm or 16mm ball joints. This refers to the stud diameter which was increased sometime in the 2002 model year.
Hopefully the upper ball joints for the early cars and ANY ball joints for the 2003 and up S Type will someday be released. . . . |
Wait... so can I get lower ball joints for my front lower controls arms? (03 str)
Can they be pressed in or out? Do I have to buy a complete spindle assembly in order to replace my lower ball joints? I have a steering wheel shimmy at 45mph that I haven't been able to cure, worse under braking, I think lower ball joint's are next to do, because ive tried a few things already, |
Thanks for the link maxthrottle
Originally Posted by tbird6
(Post 617566)
Hopefully the upper ball joints for the early cars and ANY ball joints for the 2003 and up S Type will someday be released. . . . s types at partsgeek If you google for the ball joint with year you get to the right page. |
Great information.......... Thank You !
If you get the ball joints for the later S Type. Let us know if they fit and how the install went.
(Post 1613804)
If you get the ball joints for the later S Type. Let us know if they fit and how the install went..
