XJ ( X351 ) 2009 - 2019
Coolant leaking from radiator cap + car taking longer to start
Old Feb 22, 2025 | 03:23 AM
kamranki's Avatar
Default Coolant leaking from radiator cap + car taking longer to start
Hello all,
My XJL started doing this suddenly just today:
- Taking much longer to start (many more crank turns). It goes on for approx 3-4 seconds before it finally starts.
- After turning ignition off, I notice that radiator fan stays on for approx 30 sec. Also, bubbling sound coming off from some tubes (can't see any leaks on them).
- Coolant leak from radiator cap.
​Engine temperature guage in dash is at normal level. No loss in performance either. I am allowing the car to cool completely down to check for change in coolant level.
Any suggestions?
Kamran
Old Feb 22, 2025 | 06:02 AM
Vasara's Avatar
The sympthons point to a head gasket. I dont recommend to use the car before repair, because the cylinder block are made by compacted graphire iron and hot escaping flowing exhaust gasses can make pernament unrepaireble damage.
Old Feb 22, 2025 | 07:42 AM
kamranki's Avatar
Upon cooling down the vehicle, I can see a crack on undeside of radiator cap. Also, coolant level low. I suspect 2 separate issues:
- Coolant level low due to leak in radiator cap.
- Car taking much longer to start due to some other reason.
Kamran
Old Feb 22, 2025 | 08:51 AM
12jagmark's Avatar
Originally Posted by kamranki
...- Car taking much longer to start due to some other reason.
Is you oil level full & do you have it (& filter of course) changed often (8k kms more or less)?
A lot of things can impact how an engine starts - spark plugs/gaps, battery strength, starter motor health, fuel (both gas & air intake).
Then there are things like compression that are very likely (and hopefully) not your problem as they're more in-depth & serious.
But as you & others recognize the cooling system needs urgent attention too.
Old Feb 22, 2025 | 10:24 AM
clubairth1's Avatar
Community Influencer
You don't mention how many miles but with a 2015 your due for a good amount of maintenance. Has the water pump been changed? How about the failure prone plastic cooling pipes? Coolant is good for 10 years and your there. Plugs are 100K miles but again lack of car information will always limit any useful suggestions.
As posted above how old is the battery?
What is the resting voltage of the car after it has sat all night?
If concerned about head gaskets as Vasara posted above (Note the SC V-6 is alloy and not an iron block) you can use a test fluid to check for combustion gases in your coolant. It's a quick and easy test too. Most any auto parts store will sell this kit.
Be aware that the dash temperature gauge is more properly called an indicator as it's NOT a gauge and has been damped to read in the middle position over a fairly wide range of coolant temperatures. Some of us use aftermarket scanners that do read the actual coolant temperature in degree's as added insurance.
Old Feb 22, 2025 | 11:22 AM
kamranki's Avatar
The car currently has 147,000 km on it. The oil and filter were changed at 141,000 km, and the plastic cooling pipes have been replaced. However, I’m unsure about the condition of the water pump, spark plugs, or ignition coils. The battery is relatively new, having been installed three months ago.
I bought the car at 137,000 km from a certified auto dealer, and it came with a two-year warranty, which still has six months remaining. I’m considering calling a recovery service to have it taken to the workshop.
Old Feb 23, 2025 | 01:47 AM
kamranki's Avatar
OK connected ODB scanner and see these two error codes:
P0335
Crankshaft Position Sensor "A" Circuit
P0324
​​​​​​Knock/Combustion Vibration Control System Error
Old Feb 23, 2025 | 01:56 AM
Vasara's Avatar
Crankshaft position sensor is vital for starting the engine. Not sure if knocking sensor is in same harmness but worth to check wiring connectors.
Old Feb 23, 2025 | 09:39 AM
clubairth1's Avatar
Agree with Vasara. Get this fixed first. Crankshaft sensor is an important one.
Do the codes come back after you erase them?
Old Feb 23, 2025 | 11:52 AM
kamranki's Avatar
Haven't cleared the codes. Should I try clearing them? Car is still taking awfully long to start.
Old Feb 24, 2025 | 08:02 AM
clubairth1's Avatar
Up to you and with the crank sensor code I think I would change the sensor. Is it expensive or hard to change?
I have never had that problem and it's not common either.
Anybody have a part number or a thread on swapping it out?
Don't know if this will help or confuse the situation?
Attached is a start sequence for the X351 cars. I got from another XJ owner. Thanks to who ever it was!
File Type: pdf
Old Feb 24, 2025 | 09:15 AM
12jagmark's Avatar
U...I think I would change the sensor. Is it expensive or hard to change?
After a little more looking it looks like it might be the C2Z17676 (Supercharged), for the V6 SC engine.
Powertrain Control for 2015 Jaguar XJ | Jaguar Annapolis Parts
It shouldn't be too hard to replace (depending on how mechanically hands-on the owner might be of course). It's on the lower left side (looking forward from the cabin of course) of the bell housing, held in place with one bolt/screw.
But as you suggested, not much to fail there, but it's possible; no moving parts. Just a magnetic sensor.
Old Feb 24, 2025 | 10:28 AM
Vasara's Avatar
Seen sometimes sensor full of rusty metallic crap blocking the signal, but mainly from manual trasmission vehicles. (metal particles from clutch & flywheel)
If the sensor fail its so that the wires have got loose inside of molding. (vibration or water ingress) Like you wrote: Not much can go wrong in it.
Old Mar 12, 2025 | 03:18 AM
kamranki's Avatar
OK, got the crankshaft position sensor replaced (got OEM style from Amazon) and all is well. Also replaced coolant reservoir tank lid.
Old Mar 12, 2025 | 10:08 AM
clubairth1's Avatar
We don't see this very often. How hard was the repair?
Any pictures or instructions?
Old Mar 12, 2025 | 11:09 PM
kamranki's Avatar
I brought it to a workshop for this task, but it seemed to be a relatively simple job based on what I was told. The mechanic explained that he lifted the vehicle, removed a few panels from underneath, and was then able to access the bolt for the crankshaft position sensor.
Crankshaft Position Sensor (Part No. C2Z17676) = $ 50
Labor = $ 30
Old Mar 13, 2025 | 06:36 AM
clubairth1's Avatar
Now that is a nice ending to a Jaguar repair! Heck I did not think you could get away from a dealer on anything for $80!
Thanks much for completing the thread.
It's so disappointing when threads just die in mid-stream. Did they get if fixed? Got rid of the car?
We are left wondering.
Old Today | 05:18 AM
danu99's Avatar
Default Radiator with screw in it?
Hi guys….
I changed the transmission bushing and looking around the engine…… because I want to replace the radiator fan, I saw a oupsi……
encircled with yellow…..
there is a screw in the radiator…..!!!!!!!
so…. Can someone help me with , what’s that….. it was a hose there and if so…. To where!?????
obviously…. That shouldn’t be like that…..
so…..HELP please
i looked at some radiators online…. And I saw this…..is that something? Is that leading anywhere? Is there a pipe missing?
ufok
Sep 23, 2024 10:34 PM
Harry Peter Rose
Feb 15, 2018 05:46 PM
jaguarmarkv
Mark V - X 420G
Jun 16, 2016 09:21 PM
Jag-o-nomic
Sep 4, 2015 03:55 AM
Noxparadise
Jun 5, 2012 06:03 PM
