XJ XJ12 ( X305 ) 1995 - 1997
View Poll Results: Steering rack and pinion MNA 3891 CB I need a replacement one
I need a rear speed sensor for my x305 v12
0%
Trac control lights and aba light is on
0%
Voters: 0. You may not vote on this poll
X305 v12 , steering rack and pinion
Old Apr 25, 2026 | 12:47 PM
Geansouza's Avatar
Default X305 v12 , steering rack and pinion
I need help with a rebuilt steering rack and pinion ( MNA3891CB) with servo t. Can’t find any refurbished one in USA. Does anyone know where I can get one. Thanks a lot
Old Yesterday | 11:41 PM
Parker 7's Avatar
The leak you see can be the lower hose fittings on the bottom of the reservoir
The dedicated speed sensor is the rear car's left only and should read about 1 volt A / C when wheel spun in car fwd direction , there are 2 part number groups in X300 production
Someone did find a loose sensors connector under the rear seat pan but a lot of work to get to
There is also the brake switch which contains 2 switches , one dedicated to the brake lights so it may seem fine
To see this switch would be pin 20 on the module connector
Old Today | 08:16 AM
Geansouza's Avatar
Thank you for the reply,
malc4d
Jun 14, 2024 08:09 AM
gulley67
Sep 9, 2022 01:03 PM
MLRocafella85
Apr 2, 2011 05:44 PM
Rique
Oct 2, 2009 03:19 PM
