ABS, Engine light, random probs...
2 Attachment(s)
Ok, I know I replied back to my intro with some of this, but made a new thread here, to go a little more detailed.
--- previous post --- Went from a ABS light to, no cruise light (yea looked up and found this is normal with engine probs), then to over heat (not slow either, it just like 2 seconds maxed out), then car just dies. Shut it off and starts right back up, after driving another 10mins does exact something. So this is going to be interesting, also managed to find ALOT of previous custom stereo wiring in the car, so I'm sure someone has screwed up something since jag's seem to be very unforgiving to custom audio (unless done correctly). --- So after before all this overheating and dying started, the yesterday I put a cheapo code reader on it, because driving home after buying it the engine light came on. (paid cash, no warranty, no biggie, I like, I'll fix it) This is what it gave me... 1 of 4 ($18) P1603 2 of 4 ($28) C1145 3 of 4 ($11) P1000 4 of 4 ($28) C1145 I know this was a cheapo reader, so now that all this other stuff is going on, I plan on firing up my laptop and seeing if I have any software that can make heads or tails outta this jag's computer. I have an ELM327 Interface USB cable that I'm hoping should work with it. Also going to find a jag' dealer around here and see if it has been fixed with all the service problems reported because I know I can hear what sounds like either drive shaft or rear differential whine, hard to tell though which. Also need to fix the rear trunk, have to go hit it every time I open it because the trunk light stays on. Well I'll continue to update on this thread until all these problems are fixed. Anyone have any ideas about type of software to use with my interface cable? or anyway to re-flash the computer? Oh, here's my first pic of it! ...randall |
C1145 DSCCM Dynamic stability control RH front wheel speed sensor circuit fault
POSSIBLE CAUSES RH front wheel speed sensor circuit: open circuit, short circuit to B+ V, short circuit to ground P1603 TRANS OBD II TCM EEPROM failure POSSIBLE CAUSES Battery disconnected while the ignition is switched ON B+ power supply circuit: open circuit TCM failure |
Originally Posted by Bud Tender
(Post 672168)
POSSIBLE CAUSES RH front wheel speed sensor circuit: open circuit, short circuit to B+ V, short circuit to ground P1603 TRANS OBD II TCM EEPROM failure POSSIBLE CAUSES Battery disconnected while the ignition is switched ON B+ power supply circuit: open circuit TCM failure as far as the other, any ideas how to fix an EEPROM failure? |
I'd like to know how you can read C codes with a cheapo reader - did the guy who sold you the reader appear out of an old oil lamp?
Here's a thread on wheel sensors https://www.jaguarforums.com/forum/x...-failure-3197/ Odd random fault codes are often due to a failing battery - get it checked at an autoparts store JIC. |
Originally Posted by steveinfrance
(Post 672206)
Here's a thread on wheel sensors https://www.jaguarforums.com/forum/x...-failure-3197/ Odd random fault codes are often due to a failing battery - get it checked at an autoparts store JIC. I'm leaning more towards failing battery, this weekend I got under the hood and found that it has a brand new battery installed not even a month old. Along with a bunch of other little things. |
12 Attachment(s)
Well definitely need to find some software that can read this car's ECM from a laptop. The USB to ELM327 worked fine and saw it, but didn't have any software that would work correctly with it.
Had cleared those codes the hand held reader gave me, just to get a fresh set or see if they repeated. And sure enough got these.. P0116 P0430 P0420 P1000 Fixes done this weekend... * Cleaned the MAF sensor * Changed Coolant temp sensor * Changed clogged air filter with an K&N air filter reset ECM and ran it for about 50 miles and so far no more engine codes, but gonna give a few days of driving to call it good. Also found that someone had tore out the factory speakers in the doors and installed some 6-1/2" Dual DS-Series 2-ways (walmart crap speakers). So when to a local audio shop and bought some 6-1/2" Polk Audio DXi-6500 (components), right now running them off the factory head unit. Managed to have time to install the front and back passenger side. Next weekend plan on getting the other two doors done. Here are some pics as well. |
Looks good - you'll need to see a P1111 (all tests complete + passed) soon then you can relax !
(Post 674108)
update:
So took jag' to muffler shop today to find out the cat's are crazy $$$ to change and can't be gutted easily either. But was kinda relived to hear that they were ok and not causing my problems. So broke out my laptop and drove around monitoring the car with PCMscan & ScanXL also a few others just to see if they would work. But pretty much ended up finding a really bad miss-fire in cylinder 3. So parked the car and popped the hood and started really going over the engine with more detail. So far have found a list of things needing to be fixed and some I still can't find parts for. But here's the list so far. So far only have made it down to spark plugs. -Throttle Body connector going to throttle missing, the wires were just connected to it with crimp connectors and pushed in plug on TB. -Vacuum line on top of intake (one on right) the plastic lock that holds it, was broke and it was loose causing a whistling sound. -Vacuum line going to rear valve cover, not only was broke at valve cover but also broke where it curbs 90deg and held together with heat shrink, the heat shrink and shrunk to point no air was able to go thru. -Found multiple connectors locks broke. btw, not sure if this is right but the cylinder order I was going off from. 2002 Jaguar 3.0 V6 1, 3, 5 2, 4, 6 -Found 3 different types of ignition coils, 2 from FoMoCo, 1 from China (this one the boot that cover spark plug wasn't sealed to coil and fell off after I pulled it out, it also didn't make that pop'n sound when you pull the coils, lastly it was the one in cylinder 3), and 3 that looked like the factory originals. -Found someone installed Bosch Platinum spark plugs, gaped at .040~043 (all 6 were gaped different). -Also found cylinder 1 coil was loose, tried to see if it would tighten and found the place the screw goes into on the valve cover was stripped out bad enough I just pulled the coil out without have to unscrew it. So now that I have a list to work on and waiting on parts, should be a fun week. Anyone know of anything else I should check or go ahead and fix while I have it all opened up. Right now I have 6 Coils ordered, already bought NGK Iridium (gap'd at .054, hope its correct because this spark plugs are a pain in ass to gap without breaking). Also have on order the connect to fix Throttle connection. Still looking for these vacuum line replacements or fixes and a way to fix that stripped out screw hole on the valve cover. |
I had alot of the same codes and the no cruise control and ABS lights. It was the vacuum line to the brake booster. I had another vacuum leak that caused it to run rough. Good luck
Originally Posted by Jagmom
(Post 683953)
Originally Posted by Randallc79
(Post 683220)
update:
So took jag' to muffler shop today to find out the cat's are crazy $$$ to change and can't be gutted easily either. But was kinda relived to hear that they were ok and not causing my problems. So broke out my laptop and drove around monitoring the car with PCMscan & ScanXL also a few others just to see if they would work. But pretty much ended up finding a really bad miss-fire in cylinder 3. So parked the car and popped the hood and started really going over the engine with more detail. So far have found a list of things needing to be fixed and some I still can't find parts for. But here's the list so far. So far only have made it down to spark plugs. -Throttle Body connector going to throttle missing, the wires were just connected to it with crimp connectors and pushed in plug on TB. -Vacuum line on top of intake (one on right) the plastic lock that holds it, was broke and it was loose causing a whistling sound. -Vacuum line going to rear valve cover, not only was broke at valve cover but also broke where it curbs 90deg and held together with heat shrink, the heat shrink and shrunk to point no air was able to go thru. -Found multiple connectors locks broke. btw, not sure if this is right but the cylinder order I was going off from. 2002 Jaguar 3.0 V6 1, 3, 5 2, 4, 6 -Found 3 different types of ignition coils, 2 from FoMoCo, 1 from China (this one the boot that cover spark plug wasn't sealed to coil and fell off after I pulled it out, it also didn't make that pop'n sound when you pull the coils, lastly it was the one in cylinder 3), and 3 that looked like the factory originals. -Found someone installed Bosch Platinum spark plugs, gaped at .040~043 (all 6 were gaped different). -Also found cylinder 1 coil was loose, tried to see if it would tighten and found the place the screw goes into on the valve cover was stripped out bad enough I just pulled the coil out without have to unscrew it. So now that I have a list to work on and waiting on parts, should be a fun week. Anyone know of anything else I should check or go ahead and fix while I have it all opened up. Right now I have 6 Coils ordered, already bought NGK Iridium (gap'd at .054, hope its correct because this spark plugs are a pain in ass to gap without breaking). Also have on order the connect to fix Throttle connection. Still looking for these vacuum line replacements or fixes and a way to fix that stripped out screw hole on the valve cover. Well finally can say at 1:30am, managed to fix all these problems listed. So far after some major computer reset's, she's running smooth. So like before guess I'll give it a few days and see if she's still running good. Then I can go back to focusing on the cosmetics things that need fixing! |
| All times are GMT -5. The time now is 06:03 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
