AC Blowing warm on drivers side but cold on passenger side?
I have a 2002 x-type 2.5 The air is blowing warm on the Drivers side but cold on the passenger side. What controls this?
Thanks. |
SEARCH is a marvelous tool =
https://www.jaguarforums.com/forum/x...whassup-37669/ https://www.jaguarforums.com/forum/x...ws-cold-57150/ https://www.jaguarforums.com/forum/x...er-side-39722/ Etc., etc., etc........... |
Thank you Dell. I did do a search in the forum search bar and found only one post with no real explanation other than "Blend Door" I have tried searching the forum many times and get mixed results so I am clearly not searching with the right terms....
The ones you found were much better information. Sorry for the trouble. I will try a little more freon, It is a reconditioned alternator and I was thinking there is a part that needs to come out and be reversed for better AC but today I just noticed that it is actually cold on the pass side and not just blowing cold as it should throughout all vents. This is easier to do than drain and refill. |
I think I figured out the search, it keeps defaulting to threads instead of Posts
