Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   X-Type ( X400 ) (https://www.jaguarforums.com/forum/x-type-x400-14/)
-   -   CDC Error? (https://www.jaguarforums.com/forum/x-type-x400-14/cdc-error-7238/)
deberly Jul 21, 2008 09:48 PM
CDC Error?
CD Changer stopped working today. Just got to the end of a CD, froze and now gives me a CDC error when I try to play it.
I removed changer and all CD's were there. Changer goes in and out without any problems. Radio and Tape still work so I do not think it is a fuse. I did not hit a bump - it just froze up.
Is there a way to reset it or does anyone have any ideas?
As always thanks for your time!
D
2003 X-TYPE
deberly Oct 25, 2008 07:38 PM
RE: CDC Error?
UPDATE
Changed the battery and it fixed the problem....
D
Dennis Oct 25, 2008 07:58 PM
RE: CDC Error?
No problem, glad we could help..:D:D
Seriously..seems a weak battery does all kinds of crazy stuff..glad you got it fixed..
bojangles Oct 25, 2008 09:59 PM
RE: CDC Error?
you removed the changer? or Cartridge?
did you really change the battery or just disconnect it for a while?
mbannister Dec 5, 2008 08:46 AM
RE: CDC Error?
This happend in mine as I was driving to work this morning.
Battery is fine so not sure what to do about it.
xande007 Feb 23, 2014 05:05 AM
Hi all,
I today have now a similar problem. "CDC error" is displayed. My cartridge is not released when "eject" button is pressed. My CDs are inside of the jammed cartridge. Before I fiddle the changer with a screwdriver, I would like to hear from any advice in here first about doing the fiddling manually.
Any advice, please? Any ideas, please? Do you think it's a weak battery?
Thanks in advance!
Alexandre
Buxton - UK __________________
xande007 Feb 23, 2014 02:11 PM
Hi all.
In the end, I used a tiny thin screwdriver around the cartridge whilst pressing the eject button. After a few attempts of fiddling, eventually, the cartridge came out.
I put it back on into the case slot, and... IT'S WORKING NOW, as it should be: the CDs are playing OK now.
No more CDC error... until the next time!
I think I will keep the tiny thin screwdriver inside my car for future use.
Thanks anyway!
Alexandre
Buxton - UK
stevewarry Mar 9, 2014 04:59 PM
CDC Error
Had the CDC Error message come up on my S Type 2.7D 2005. Searched around for a while and a guy told me to GENTLY tap the CD magazine, as this may release a disc that has become stuck.
So, I did what he said,I tapped the magazine with the handle of a screwdriver, and, hey presto, all the discs loaded, and its working fine now.
Hope this helps someone out there:icon_toast:
Ukrichard Oct 27, 2016 11:05 AM
CDC errot
Thanks.
A gentle tap and all was well.
bigdiver Oct 29, 2016 06:45 PM
I'll be dipped! Whacking the cassette a few times with whatever tool is handy does the trick.
I had a "CDC error" and the cassette would not eject. Now it works fine.
© 2026 MH Sub I, LLC dba Internet Brands
