Cylinder number locations
Hi Sorry to start a new thread about this. I keep getting conflicting information regarding cylinder location for a 2002 X Type 2.5. I need to know for certain that cylinder number 5 is the far left rear cylinder as viewed when sitting in the car. This is a U.S. model so this would be drivers side rear bank.
Thanks Ken |
Sitting in the car the cylinders closest to you from right to left are #1, #3 and #5. The cylinders are located closest to the passenger compartment.
The cylinders closest to the radiator are #2, #4 and #6 from right to left. |
Here is the cylinder numbering scheme for the AJ-V6:
https://cimg4.ibsrv.net/gimg/www.jag...8bdddc7c0c.jpg |
NBCat, some engineer must really hate techs. Why would you take the same engine, fire it in the same sequence (ie, 2 cylinders nearest the front of hte engine, the 2 in the middle, then the 2 on the back side), but, give the motor a completely different cylinder numbering all because it went into a different car. That makes about as much sense as shoving bamboo under your fingernails.
Originally Posted by Thermo
(Post 2234671)
Thanks for all the help. I nearly changed the coil on cyl 1 instead of cyl 5. P0305 misfire.
Ken |
(Post 2234671)
Jaguar took a long time to follow the international standards. You're seeing the results of before & after. Following the standards means things like OBD tools report the cylinder / injector number consistent with the car :) |
