Engine issue 2005 x type 2.0d
Look up in search "flashing glow light" then do the "Mr. Muscle" fix.
I have a quick and easy solution that might work for you.
Try disconnecting the egr valve clip so it isn't receiving power anymore or blank it off with a blanking plate. I did this when i had loads of black smoke out the back and the car with kinda cough and jutter for 1 or 2 seconds and the puff... loads of smoke and the car would drive again , this will get worse and worse until the egr valve fails . , if you keep your car at a steady speed does it jutter forward and backward like a shaky feeling? I brought it to the garage and they said injectors.. I barely got the car home and the next day I took out and dismantled all the injectors and cleaned them and put them back and it didn't fix the problem, I then bought a blanking plate and put it by the egr valve and no more black smoke and nice smooth driving |
Blanking plate
You could buy one on ebay or maybe amazon too for around 3-5 euro/pound.
Or you could make one if you had some metal at home and the tools |
Originally Posted by Dell Gailey
(Post 2046136)
Originally Posted by Luke Farrell
(Post 2046516)
Try disconnecting the egr valve clip so it isn't receiving power anymore or blank it off with a blanking plate. I did this when i had loads of black smoke out the back and the car with kinda cough and jutter for 1 or 2 seconds and the puff... loads of smoke and the car would drive again , this will get worse and worse until the egr valve fails . , if you keep your car at a steady speed does it jutter forward and backward like a shaky feeling? I brought it to the garage and they said injectors.. I barely got the car home and the next day I took out and dismantled all the injectors and cleaned them and put them back and it didn't fix the problem, I then bought a blanking plate and put it by the egr valve and no more black smoke and nice smooth driving Yes, it does jutter back and forwards at about 1700 / 2000 rpm. Will try and disconnect it, see what happens. I was thinking the egr, the lack of codes stored ref the egr has swayed me away from it however. Is it normal not to have anything stored? Thanks, Ben |
