Engine stutters under load with fault codes: P0174, P1549, P0171, P1000
P0174- bank 2 running too lean
P1549- IMT valve failure??? P0171- bank 1 running too lean P1000 So my check engine light is back on in my 2005 3.0 X-type and has revealed all of the above codes, with P1549 being a new one to me. I've previously attempted to address the others for the engine running too lean. My Jaguar specialist mechanic and I previously suspected a vacuum leak, but he didn't find one. He replaced the Mass Airflow Sensor and I had him do the Fuel Filter a couple of months ago and that resolved it for a short while. However, the car now hesitates under load such as joining the freeway. Any help on this is greatly appreciated! Cheers, Ian |
Try changing the two IMT o-rings and see what you have. Simple easy and cheap to do.
That P1549 sounds like it could be a wiring issue or something with the connector. I don't think I have ever seen that code posted here before, so not familiar with what triggers it. IMT Valve 1 (bottom) disconnected IMT Valve 1 (bottom) to ECM drive circuit fault IMT Valve 1 (bottom) power supply circuit fault IMT Valve 1 (bottom) failure Not sure which one is Valve 1. Maybe check the wiring/connectors on both. |
Thanks Alfadude.
Is the IMT ring the same as: OES Genuine Intake Manifold Gasket
https://www.amazon.com/OES-Genuine-Intake-Manifold-Gasket/dp/B006C0RD66/ref=wl_mb_wl_huc_mrai_3_dp?ie=UTF8&pd_rd_i=B006C0RD66&pd_rd_r=N38RRPCB6KXFPV28E4YG&pd_rd_w=V5nvP&pd_rd_wg=y52d6
It looks to be from the following video: |
That is correct, but that seems like a lot of money. I would guess if you shopped around you could get them cheaper. Try some of the forum sponsors.
Found them for $6.77 on SNG Barrat:
https://www.sngbarratt.com/us/#!/Eng...d-7164151beff0 |
