Factory HIDS
hi, i was wondering is it possible to change out your halogen headlamp with a xenon headlamp?
yes you can, simply purchase the Xenon HID head light assembly, remove the front bumper, remove the halogen head light assembly and install your new Xenon assemblies. The factory wiring harness is identical for both. It's plug and play. (new Xenon HID assemblies cost $900+ each)
If you go to e-bay, be sure to check the "adjustment screw". Normally these are already broken and the seller does not realize that they are selling a damaged part. If you were thinking aftermarket kit. There are several to choose from. |
and if you buy broken ones you can take them apart and repair. I do these on the side for extra money. starting @$125 a pair and up. Thats you sending yours to me
the autobody shop put xenon headlamps in and when i got the car back they were not working. they were telling me that the wires were ****ed up or some ****. now that i got the xenon headlamps will the headlights auto adjust
Mine is an 02, it does not have the auto adjust lamps. You have to manually set them. I don't know too much about all the "options" it might have had from the factory. I do know tht the S-type has auto adjust if optioned with it. As far as the x-type auto adjust????
I thought ALL HID's Auto adjust from the factory. It's required by law if the lights are to be legal.
Hence y all the aftermarket products tend to say "For off-road use only" |
Originally Posted by and1carter
(Post 106370)
When I modded my X-type, I removed the auto levelling mechanism from the HID's and run the extra ground wire to the chassis. I never had issues with blinding other drivers. If you left the stepper motors for auto levelling in the HID's when you put them in your car, the lights will be pointing down with no chance for adjusting them. Drop me a PM if you want the PDF with the schematics so you can see the defferences. - Tim |
HIDs
Thanks for this info as i think i am in deep s*** with my headlights as well
some one has fitted these HIDs to my car X type I was told that they need adjusting, so I took it to a garage and sked them to line them up for me only to be told the adjusters must be broken, so am I looking for a new pair of headlights or can they be fixed????? |
If you need them fixed, see post #3 above turky.
well i bought my car used and it came with halogen headlamps and then recently i got in an accident and when they checked the VIN for the headlamp they said it came from the factory with xenon headlamps so do you think that it will have the auto leveling feature?
How would you know if you "never had issues blinding other drivers" ?
Well Chris my off side was way out when you can see the driver of the car coming in the opposite direction quite clearly in the dark on diped beam then you know you have problems, well I had mine checked out and sure enough the adjusters were broken.
