have you replaced a rear wheel bearing?
a new rear wheel bearing is needed. i have done one before and recall the old one was very difficult to remove and i damaged the threaded end of the driveshaft trying to remove it.. are they always so hard to remove or do they also come off pretty easy. from what i remember i pounded the end if the driveshaft to "shock" it off. also..any tips for removal |
Wheel bearing, driveshaft?
Modeo III same process = If you mean the shafts to wheel bearing, a slide hammer or bearing puller would do probably. |
thanks dell but neither of those show an AWD car. im really looking for info about how to get the driveshaft/halfshaft out of the splined hole or more specifically...does it EVER come off without major force. pullers are only good if you have the right one for the job. with a million styles and sizes..unlikely, and i know from last time.none that i have fit |
or maybe i ended up using a puller and dont remember....all i remember is it took longer than it should and i ruined the threads on the shaft trying to shock it off |
This is kinda what I was thinking would work =
that actually rings a bell, maybe thats how we finally did it. before i take it apart ill take the new hub to store and look for a good puller. |
